Revo 2.5 plzz help by everyone...
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing Genesis Monster Truck - RTR - RTR
Seller:  solidgold5
Details:   $250.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Revo 2.5 plzz help by everyone...
Page: [1]
Login
Revo 2.5 plzz help by everyone... - 5/13/2008 2:24:39 PM
didrace
Status: offline
Hello everyone..
I have a revo 2.5 and i am thinking to convert it to 3.3.. what part do i need? is it worth it?
Please help is very urgent ..because i will buy the stuff before i leave Uk..
Also tell me everything i need to buy to make my revo bulletproof..
Just tell me what parts you break and i will change them ..starting from drivetrain to towers and so on and so for
Plz reply to me as soon as possiple
       Post #: 1
RE: Revo 2.5 plzz help by everyone... - 5/13/2008 7:55:28 PM
didrace
Status: offline
Guys anyone????
(in reply to didrace)
       Post #: 2
RE: Revo 2.5 plzz help by everyone... - 5/13/2008 9:23:30 PM
iamnot
Status: online
the only thing you
need
to upgrade the engine
is a 3.3 engine
everything else
transfers over
as far as toughening up the truck
wow, you could get tons of stuff
but
i put a .18tm on my 2.5 revo
and the only problem
i've had in over a year
was ruining one set of diff gears
so i don't have anything i feel
is a necessary upgrade
_____________________________
two kinds of people i never believe - fanboys and haters
they never tell the whole truth
       Post #: 3
RE: Revo 2.5 plzz help by everyone... - 5/13/2008 9:39:01 PM
NitroVenom
Status: offline
So do you want to convert just the engine or the whole chassies?? The engine is a direct swap with the 2.5
When In Doubt, Throttle Out
(in reply to iamnot)
       Post #: 4
RE: Revo 2.5 plzz help by everyone... - 5/13/2008 9:42:28 PM
d40sithui
Status: offline
lol iamnot, why do you always talk like that
(in reply to NitroVenom)
       Post #: 5
RE: Revo 2.5 plzz help by everyone... - 5/13/2008 10:40:43 PM
didrace
Status: offline
Guys i wanted to change the 2.5 chassis to 3.3 because i thought it will be better.. as for the engine i have the conversion kit for a big block..
So the engine is not my problem..
the problem is that i want a bulletproof truck..i will use an lrp 28 version 1 or the savage 25 engine i dont know yet.. and i dont know if they will fit with the traxxas conversion kit..
tell me guys anything that you know it breaks..
the towers?
the steering system?
the pivot balls?
the chassis?
the bumpers?
steering blocks?
skid plates?
bulkheads?
differentials?
spider gears?
cups?
cases?
axles?
spur gears?
(in reply to d40sithui)
       Post #: 6
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 12:28:02 AM
NitroVenom
Status: offline
I HATE the stock shock rod end caps. I bought a nice set of alluminum ones and have yet to find anymore problems with anything else. The truck is pretty strdy. Just buy a better air filter and you'll be ok.
For the conversion, you will need the 3.3 chassies, longer steering arms, 3.3 chassies brace, and a wide gear ratio set for the tranny(optional).
Now if you want to put a big block in their with traxxas mount, and you want to use a pull start or roto-start, your gonna need extended a-arms because the starters don't clear the rear a-arms. With the extended a-arms, it will clear easily.
Edit: and your gonna need to put some heavier weight oils in the diffs. I'm running 40k up front and 30k in the rear. Alluminum diff cups would be good also.
< Message edited by NitroVenom -- 5/14/2008 12:31:29 AM >
       Post #: 7
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 2:00:07 AM
didrace
Status: offline
How can i be helpedby the extendet arms?
How do they differ from the stock ones and give you the opportunity to use a big block engine?
       Post #: 8
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 3:17:24 AM
NitroVenom
Status: offline
The extended arms sit farther back then the stockers, therefor, they clear the starter. A lot of people have had this problem when they installed the Traxxas big block kit.
       Post #: 9
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 3:24:18 AM
Clymer122693
Status: offline
The extended arms are not swept back at the mounting points,they are swept back where the pivot ball threads in. Thus you will not gain any clearence,the only way to gain clearing would be to extened the rear portion of the chassis.
Revo Driver: "Dude you see me get air off that thing!?!?!!" Savage Driver: "That was my Savage!!!"
       Post #: 10
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 3:45:01 AM
NitroVenom
Status: offline
MiamizFinest already went through this whole thing a while back, he had pics to explain it also.
(in reply to Clymer122693)
       Post #: 11
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 5:43:49 PM
Clymer122693
Status: offline
Explain what? That the Extended arm's give more clearence? I can take pics to prove that they dont,you actually loose clearence.
       Post #: 12
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 5:58:41 PM
rgbintx
Status: offline
I was told earlier that the New Era or the JConcepts big block conversion kits let you keep the starter, pull starter, or roto start. I haven't been able to find one of these kits yet. Anyone know where to find one?
       Post #: 13
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 6:12:16 PM
Clymer122693
Status: offline
quote:
ORIGINAL: rgbintx
http://www.impaktrc.com/product_info.php?cPath=151_39_59&products_id=339
http://www.impaktrc.com/product_info.php?cPath=151_39_59&products_id=340
http://www.neweramodels.com/item.cgi?session_id=&part_id=2553
(in reply to rgbintx)
       Post #: 14
RE: Revo 2.5 plzz help by everyone... - 5/14/2008 6:47:31 PM
rgbintx
Status: offline
Thank you!
       Post #: 15
Page:   [1]
Page: [1]
