Jburry
NB, CANADA Status: offline
Yup, I do think so! I was surprised (to put it mildly) myself the first time I ran the doppler numbers. I've run them again and again, from several sound recordings. The lowest RPM I've seen on a speed pass (with diving entry, level for about 100 yds coming to the trap) was about 17100. For confirmation, I checked what it's doing on the back stretch (after climbing a hundred or 2 feet, and turning 180 degrees) and back there it's sitting in the high 15K's to low 16K's. On the ground, it's taching right about 13K, give or take 300 for the weather. On take-off, the revs reach that static rpm sound immediately, and as the plane climbs out, so do the RPM's. About 14.5K at top of initial climb-out. First level stretch, and it's like I hit a turbo button, and it begins to unload and genuinely seems to "come on pipe". Once "on the pipe", nothing short of several hundred feet of vertical pull, or throttling back, will haul it down off the pipe. Further unloading (to almost stupid degrees) happen once I begin the dive into a speed pass. And what a wonderful warbling scream it makes on a speed pass. Other planes I fly have nothing like this engine's unloading. I really don't understand, but this engine loves to rev. I'll letcha'all know when the bearings give up. Wonder if they'll survive this whole summer? Warranty ends this coming spring, so I assume they'll die early next summer J
_____________________________
Revver Bro. #220
