Stickbuilder
FL, USA Status: online
Abu, I don't know of any that place a higher value on the static than on the flying (except for maybe some pure static shows) portion. As both Dave and Mike have said, It's a pure competition, and if you build well enough, then you probably would not want to remain in the Pro-Am classes for too long, but would wish to move into either Expert or even Team as soon as you could. After the Judging is over, we (the Static Judges) are very happy to go over your score sheets with you and explain the downgrades. We don't have the time to do this while the Judging is going on. I only have 15 minutes to check the entire outline of a model, and often that is almost not enough time. There are a few instances where a very large model takes quite a bit of time to move into a certain orientation for judging. Mike's A-10 is a very large model, and requires some planning for he and his crew to re-orient on command. If at all possible, you should attend Top Gun (even as a spectator). It's mind numbing. Pure culture shock to see so many outstanding examples together at one time. There are obscure models that you will only see at such a venue. What are the odds of seeing one Fairey Swordfish, much less a pair of them. Ed Newman's Storch alone is worth the trip, as is Dave's Duster, or Mike's Hog. There are others that would alone make the trip worthwhile. It's hard to pick a favorite, because they are all top shelf models. The Competitors are Top Shelf as well. I've never seen any pettiness, or backstabbing, and in fact, I've seen assistance being given by others who stand to lose if you are able to continue. These guys are Gentlemen in the truest sense of the word. Bill, AMA 4720 WACO Brotherhood #1
_____________________________
It's easy, just glue all the pieces together, and sand off everything that doesn't look like an airplane.
