DeviousDave
I'm asking because it seems that the "RR" in the motor I have stands for Reverse Rotation! I found this motor in a clean but frozen state, and gave it to someone (a very modest "Someone" ) under the "Pennies from Heaven" program, but eventually it ended up back on my doorstep like a sack of abandoned kittens. The "Someone" I sent it to didn't have any luck getting it to run and felt badly about having it and not being able to run it and appreciate it, and felt it needed to go to someone who might like to have it. Naturally, curiosity got the better of me and I took it apart. Hmm... needle passes fuel.. has good compression,... tank vents are clear.. Hmm. I bolted it back together to also admit defeat, stopping to flip it over a few times before tossing it in a corner. "I wonder if it's a vacuum leak?, nahh, not likely. Boy, this thing sure does sound anemic when you flip it over..." The angels sang from the heavens and a lightbulb lit in my Brain Housing Group. "Holy $#oke$ this thing has a reverse rotation drum in it!! Did they ever make these in a reverse running configuration????" I checked, and sure enough, the intake venturi sucks in with the motor turning backwards. So there it is, are these motors supposed to run backwards, or do I have some kind of wierd-alice motor with an accessory part intake valve in it?
< Message edited by DeviousDave -- 5/14/2008 3:25:11 AM >
