captinjohn
MI, USA Status: offline
quote:
ORIGINAL: AussieBrett Guys..i have recently purchased a few excellent test stands from the UK via ebay...and was about to use them...(always ran motors in on planes till now)....I have learnt to start the motor, let it run a bit (few mins rich) then turn off and cool, then repeat a few times (hot-then cold-hot then cold etc)...so i have learnt something from this thread...BUT, i cannot see how the air blowing from the prop doesnt cool the motor, and i cant see how the motor can be damaged if run on the richer side...surely no one is dumb enough to run a motor, anytime, anywhere (on ground or in plane) if it is lean and at max rpms..that is dumb...??.but....WHY doesnt the air from prop cool the motor....surely if motor running mostly at lower rev range and then up to 70 percent max for short periods (only 100 percent for say 5 secs) on richer side on a cool day (early morn or late arvo)...WOULDNT THIS BE OK...now help me with the air from the prop theory...and if someone really experienced using test bench run ins could post what is the best way to do it from start to stop....THANKS...P.S- i have about a dozen motors to run in, ranging from OS46ax to supertigre 90 to supertigre 3250 and supertigre 2300 as well as a few tigershark 120 and a heap of ASP/Magnum 91 and 120 fourstrokes for a dozen different projects my buddy and I are all working on..all 2 strokes have pitts mufflers...great advice wanted re test stand running in, pls experienced peoples., regards brett from australia. Please read post #18 and #19 over again. Pat is one of the most experienced engine gurus you will ever meet. Best Regards Capt,n
_____________________________
I never met a engine I did not like!
