spektrum range problems
Tower Hobbies
Logged in as Guest
  Printable Version
Fly Eagle F- 16 Edward ARF,+ L/G system - ARF
Seller:  mikedenilin
Details:   $1,100.00   |  7/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> spektrum range problems
Page: [1]
Login
spektrum range problems - 5/14/2008 2:38:40 PM
airraptor
Status: offline
i have a dx-7 i had one of my planes go in today. it lost signal and never recovered. it was the full range 6 channel reciever in a fiber glass fus. it was about 1500 or so feet high. Its the ar6200 one.
Has any one else had this kind of problem.
also one note to all who have the chrome monokote on thier planes. spektrum works fine with this covering but DO NOT SCUFF the covering to give it that weathered look because the spektrum will not work. this is because of the covering acting as a RF ground. i flwe this plane over 40 flights and had problems when i used a brillo pad on it to make look more scale. it was on a p-51. the plane is in one piece still but the range check only got 20-25 feet away before signal lost. swap recievers same thing. I swaped with a know good reciever. i now have to go back to 50/72mhz or recover the plane.
       Post #: 1
RE: spektrum range problems - 5/14/2008 6:49:45 PM
Gray Beard
Status: offline
First thing, yes, my students plane lost signal and was locked out for about 6 seconds with the same radio but the 8 ch RX. {{ think it was the 8}} They have fixed the lock out problem but it will still lock out for about 1 second. You need to have the TX antenna twisted over to about A 45degree angle and that helps out A bunch.
Second thing is, there is no metal in the silver covering so you better start looking for another problem?
_____________________________
If drinking and driving are illegal, then why do bars have parking lots???
(in reply to airraptor)
       Post #: 2
RE: spektrum range problems - 5/14/2008 10:45:33 PM
airraptor
Status: offline
the covering is the chrome stuff. I have flown that plane for a long time before i decided to buff it atthe field. I flew it and had aileron problems. did range check and saw it only got 20-25 feet. swap RX at the field and had same problem. Put the first RX in the swaped plane and range checked just fine. I forgot to say eariler these RX's are the AR 6100. on the coevering I used the brillo pad to scuff off the clear part of the covering down to the aluminum layer. this makes the chrome look like old aluminum on an plane.
(in reply to Gray Beard)
       Post #: 3
RE: spektrum range problems - 5/15/2008 3:49:42 AM
telejojo
Status: offline
yes. rx came unbound with rx.........I picked up the pieces and nothing would work.I rebound it and every thing started working.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
