Engine shock mounts
Tower Hobbies
Logged in as Guest
  Printable Version
F-18F Super Hornet ARF DiamondBack - ARF
Seller:  rcjetmodels
Details:   $1,729.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Engine shock mounts
Page: [1]
Login
Engine shock mounts - 5/14/2008 5:59:14 PM
Penuts
Status: offline
I have a Sukhoi 31 68", useing a S.P.E.C 26CC
There's nothing wrong with the engine however im getting vibration and would like to dampen it down some, are there any shock mounts for that engine? I cant seem to find any.
Or any suggestion would be appreciate, My prop and spinner are balanced,this is my first gas plane,maybe im just overcautious.
       Post #: 1
RE: Engine shock mounts - 5/16/2008 12:44:23 AM
Hurri
Status: offline
all of my gas engines have rubber mounts even have the G26 with them . saves a lot of vibration thru the F/wall & airframe & also the radio . Basically I put a piece of 3/16 alum plate
on the back of eng rear of the muffler , bolted to the eng; the plate is aprox 4" sq on the G26 & has 4 rubber s a pair on each corner -total 8 rubbers , a 1/4 " or 6 mm bolt goes thru the rubbers into blind nuts in the f/wall . lock wire is connected thru the bolts to make sure they don't loosen .
(in reply to Penuts)
       Post #: 2
RE: Engine shock mounts - 5/16/2008 9:13:07 PM
iron eagel
Status: offline
quote:
ORIGINAL: Penuts
http://www.jtecrc.com/giantmounts.htm
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
       Post #: 3
RE: Engine shock mounts - 5/19/2008 1:04:45 AM
Penuts
Status: offline
Thanks guys,I'll look into that and see what i can come up with.
Thanks again
(in reply to iron eagel)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.250RCU1
