wheels questions. post your questions about wheels and tires here.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Himoto Racing Support Forum >> wheels questions. post your questions about wheels and tires here.
Page: [1]
Login
wheels questions. post your questions about wheels and ... - 5/14/2008 7:17:25 PM
ranger4x4
Status: offline
what other wheels and tire combos from himoto would work on what models? i'm gonna be looking for some new rims for my mxt and i was wondering what rims would work on it that himoto offers?
_____________________________
we are here to stay, the revolution has begun!!!!
       Post #: 1
RE: wheels questions. post your questions about wheels... - 5/14/2008 7:49:59 PM
HimotoRacingUSA
Status: offline
best bet is to use the stock setup, they are 12mm hex, have the metal ring that reinforces the hex. Just my .02
OFFICIAL SUPPORT HIMOTORACING.COM / OWNER HIMOTORACINGUSA.COM
***Its me EHROOF!!!!*** THE REVOLUTION HAS BEGUN
(in reply to ranger4x4)
       Post #: 2
RE: wheels questions. post your questions about wheels... - 5/14/2008 8:10:00 PM
ugly duck
Status: offline
You're talking about the MegaP, right Eddie? I thought it used the 17mm hex similar to the other 1/8 scale models. I'm probably wrong.
I used Traxxas Stampede wheels on my 1/10 truck and I'm not that impressed. The hub is very thick and doesn't leave alot of threads showing on the stub axles unless you modify the wheel, plus I chipped the rim on one in my first tank. I'll probably trash them and get something else when I do. I do love the ProLine Gladiator II tires, though - I got the M2 compound because I wanted them to wear a bit longer. They're much more stable and responsive, grip all surfaces that I've run them on better than the V-tread stock rubber, and they don't baloon like the original ones did.
At the same time I switched to the aluminum drive hexes from the crappy plastic ones - what an improvement! You can crank on the wheel nuts now without fear of them coming loose or locking up the wheel.
Sponsored by Redcat-Vancouver
Email: westcoasthobbies@shaw.ca
(in reply to HimotoRacingUSA)
       Post #: 3
RE: wheels questions. post your questions about wheels... - 5/14/2008 8:16:45 PM
HimotoRacingUSA
Status: offline
no bro, there 12mm. not many 1/8 mt's use 17mm, most like the tmaxx and savage use 14mm. They make adapters to convert 12mm to 14mm so you can use tires for a tmaxx or savage but i really like the design of the megap series rims, on all the models, they have a ring than surrounds where the rim goes on the hex adapter and gives it added strength. I havent heard of anyone breaking a rim yet, unless they hit something at a high rate of speed.
(in reply to ugly duck)
       Post #: 4
RE: wheels questions. post your questions about wheels... - 5/14/2008 11:16:28 PM
ugly duck
Status: offline
Huh, I must be going crazy then because I thought I saw something somewhere... Guess not!
Edit - these are 12mm hubs?
< Message edited by ugly duck -- 5/14/2008 11:22:11 PM >
       Post #: 5
RE: wheels questions. post your questions about wheels... - 5/15/2008 12:22:33 AM
HimotoRacingUSA
Status: offline
no, they look like 17mm to me
       Post #: 6
RE: wheels questions. post your questions about wheels... - 5/15/2008 12:26:16 AM
pede_187
Status: offline
quote:
ORIGINAL: ugly duck
that's guy4x4's rancho which does use 17mm
       Post #: 7
RE: wheels questions. post your questions about wheels... - 5/15/2008 12:45:10 AM
ranger4x4
Status: offline
i was just wondering if himoto had a different style of rim from the ones i have. i like the setup for how they mount and that metal ring around where the hex goes into the rim is a great design. i was also wondering if they have another tire tread that fits that rim as well. i'm not big on chrome wheels. thats why i asked the questions i did. and also for anyone else who might be kind of curious about this as well.
(in reply to pede_187)
       Post #: 8
RE: wheels questions. post your questions about wheels... - 5/15/2008 5:07:18 AM
Redharris
Status: offline
ranger.....
I believe that Himoto Does have another Tire for the MegaP 1/8.
There is a Picture of it in my MANUAL....p/n HI904-002. It is a PIN style Tire.
I'm with EDDIE.... I LIKE the STOCK look/performance.
However, I am going to do some Research on this Subject, (I've had some PM requests about this) and I will Post some INFO within the Next Few Days for you guys........
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN
http://himotoracing.com :: http://himotoracingusa.com
       Post #: 9
RE: wheels questions. post your questions about wheels... - 5/15/2008 6:01:17 PM
ranger4x4
Status: offline
your the man rich, i love the stock size i wouldn't change that at all. just the style of the wheel. and the tires are about the best i have seen for grip, they bite hard and dig real good. even on pavement which surprised me because of the tread pattern. i was thinking of having maybe a second set as a backup and for variety....ok so i also want to have more toys for my truck lol. but i noticed that running those tires on pavement they do wear very fast and i think my foams in the tires are almost done too. i heard somewhere that using memory foam in them works good. is this true?
(in reply to Redharris)
       Post #: 10
RE: wheels questions. post your questions about wheels... - 5/15/2008 6:29:05 PM
ugly duck
Status: offline
I think memory foam is better for rock crawlers, and standard foam is good for speed.
       Post #: 11
RE: wheels questions. post your questions about wheels... - 5/15/2008 7:02:23 PM
HimotoRacingUSA
Status: offline
i have heard that too, memory foam is good for the rockcrawlers.
       Post #: 12
RE: wheels questions. post your questions about wheels... - 5/15/2008 7:05:06 PM
ranger4x4
Status: offline
ok gotcha memory foam for crawling. the foams in my 1/10 viper are pretty shot too. but i know i ain't gettin those tires off the rims in one piece. same as my mxt tires. do the different colors mean anything in the foams? like hardness or softness?
       Post #: 13
RE: wheels questions. post your questions about wheels... - 5/15/2008 7:22:54 PM
HimotoRacingUSA
Status: offline
there are as many differenty foams as there are diff oils and such, lol. i will try to find out the exact information about foams but i know there are different ones.
       Post #: 14
RE: wheels questions. post your questions about wheels... - 5/15/2008 7:45:21 PM
pede_187
Status: offline
Could I post pics of my wheels and tires?
