Which paint is fuel resistant
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> Which paint is fuel resistant
Page: [1]
Login
Which paint is fuel resistant - 5/14/2008 8:16:16 PM
mustangman177
Status: offline
I am going to paint a 2 liter coke bottle for a cowl on a plane and would like to know what or if any brand of spray paint is fuel resistant to glow fuel. I thought I heard that maybe krylon or something like that is. Thanks for the help.
Cary
< Message edited by mustangman177 -- 5/14/2008 8:31:05 PM >
       Post #: 1
RE: Which paint is fuel resistant - 5/15/2008 12:30:50 PM
airbusdrvr
Status: online
Rustoleum works.
(in reply to mustangman177)
       Post #: 2
RE: Which paint is fuel resistant - 5/15/2008 1:58:21 PM
Sport_Pilot
Status: online
Krylon is not fuel resistant. You can try Plastikote acrylic laquer. Be carefull Plastikote also sells enamal which is not fuel proof. Mostly the Truck and Van paint is acrylic laquer, read the back of the can to be sure. You can find Plastikote in automobile stores. A plus is that it dries fast and doesn't run easily. BTW the Monocote paint is also acrylic laquer.
(in reply to airbusdrvr)
       Post #: 3
RE: Which paint is fuel resistant - 5/15/2008 4:28:00 PM
bkdavy
Status: offline
Painting coke bottle can be difficult. Any paint that is fuel proof may dissolve the bottle. I've not had good luck with Rustoleum or Krylon for fuel proof. The Lustrecoat dissolves the clear plastics.
One technique to try might be painting it with rustoleum, and then putting on a couple thin coats of finishing resin. That will add a nice high gloss, and its fuelproof to boot.
Brad
(in reply to Sport_Pilot)
       Post #: 4
RE: Which paint is fuel resistant - 5/16/2008 1:01:56 AM
Campy
Status: offline
If a paint STATES ON THE LABEL that it is an acrylic, there is 95%+ chance it is fuel resistant. To be certain do a test panel, then do a raw fuel test (pour some fuel on the panel and let it sit there for 5 or 6 hours, then wipe off). If it passes the raw fuel test, then do the exhaust test. Hold the panel about 10" - 12" from the exhaust of a running engine for a tank of fuel (about 12 minutes). Make sure the exhaust is going directly on the panel (a pair of gloves is nice to keep your hands from being burnt) during the test, then let the panel sit for 5 - 6 hours before cleaning.
BTW - Not all colors of Rustoleum are fuel resistant, and the ones that are typically need 3 - 4 weeks (or longer ) of drying to develope fuel resistance.
(in reply to bkdavy)
       Post #: 5
RE: Which paint is fuel resistant - 5/16/2008 4:01:29 AM
digital_trucker
Status: offline
The paint that Nelson hobbies sells is fuel resistant. Comes in Monokote matching colors too. I can vouch for it resisting 25% nitro fuel.
_____________________________
I feel I can speak for 90% of humanity when I say 'durrrr'
Skype digital_trucker
(in reply to Campy)
       Post #: 6
RE: Which paint is fuel resistant - 5/16/2008 1:59:20 PM
mustangman177
Status: offline
Thanks all for the help. I'll try Rustoleum and do a test area with raw fuel and with the engine running for 12 min. time and wipe the area to see if the paint stays.
Before spraying the coke bottle cowl, should I sand the the area to be painted with 200-300 grit sand paper to roughen the area for the paint to adhere better ?
Thanks for all the great advice
Cary
(in reply to digital_trucker)
       Post #: 7
RE: Which paint is fuel resistant - 5/16/2008 8:09:53 PM
Sport_Pilot
Status: online
Most acrylic paint is either acrylic latex which is somewhat resistant, or acrylic enamel which is not at all fuel proof. Only acrylic lacquer is truely fuel proof.
I am pretty sure the large coke bottle bottoms are resistant to most acrylic lacquers. Try a test coat to be sure.
< Message edited by Sport_Pilot -- 5/16/2008 8:12:49 PM >
       Post #: 8
RE: Which paint is fuel resistant - 7/14/2008 5:12:31 AM
build light
Status: offline
If you were to paint it on the inside you would get the gloss and the plastic itself would be fuel proof!
Robert
Keep'er light, and she will treat you right!
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
