No Lift!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> No Lift!!!
Page: [1]
Login
No Lift!!! - 5/15/2008 5:44:44 AM
sirfixalot
Status: offline
Can someone please help me with getting my AXE off the ground. Lately full throttle does nothing but lighten the heli enough to drift. I have all aluminum upgrades on it....which I've had, I have just put new blades on to see if that may help....lastly I lengthened the links but still nothing. Any ideas? RPMs seem good.
       Post #: 1
RE: No Lift!!! - 5/15/2008 5:47:13 AM
BigTruckDriver
Status: offline
wrong pitch, blade tracking? what have you done to it before it lost lift?
_____________________________
If it isn't broken,adjust it till it is.
(in reply to sirfixalot)
       Post #: 2
RE: No Lift!!! - 5/15/2008 12:35:38 PM
nscradar
Status: offline
quote:
ORIGINAL: sirfixalot
Start by disconnecting the main and tail motors from the circuit so that they dont accidentally turn on. I am guessing you are still using the stock transmitter. Plug in the battery and let the gyro initialize. then move the throttle/ pitch stick to center and toggle the idle up switch to idle 1 or idle 2, doesnt matter at this point which. Holding the flybar level, sight down the main blade and compare the chord of the blade to the flybar. they should be parallel. Also check to see that the servo arms are level and the swash is level. make any adjustment here first before proceeding. Measure the servo link length to see if they are correct. 45mm front and left side, 32mm right side.
Keeping in mind that as the swash plate moves down and the throttle stick moves up, positive pitch is being applied to the main blades. If your main blades are not level at this point you'll need to adjust the servo links, shorter to increase pitch, longer to decrease pitch. Using this method you can adjust your pitch curve mechanically to suite your flying style.
Now that your pitch curve is set up for the stock transmitter, unplug the battery, plug in the motors. Set the idle up switch back to normal and return the throttle stick to down position.
Try it now.....
       Post #: 3
RE: No Lift!!! - 5/15/2008 2:53:23 PM
PilotLight
Status: offline
The most common problem for this is the guys fix the heli after a crash and install the blade grips backwards. The ball link must go towards the trailing edge of the main blade. I guess this means your seesaw is upside down too.
(in reply to nscradar)
       Post #: 4
RE: No Lift!!! - 5/20/2008 2:31:53 AM
para_seb
Status: offline
hey i was battling the same issue for a while a now.. Since i've finnaly put a 1350mah Lipoi in it, it worked like a charm... Hope it helps..
(in reply to PilotLight)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
