RE: DL 100 - New Twin on the Block!!
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine by Southeast R/C Engines, LLC.
Seller:  XYZUSA
Details:   $259.95   |  10/13/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DL 100 - New Twin on the Block!!
Page: <<   < prev  6 7 8 [9] 10 11 12 13 14 15   next >   >>
Login
RE: DL 100 - New Twin on the Block!! - 6/28/2008 9:03:04 PM
2robinhood
Status: offline
Made my maidan today with the Lanier Yak 54 ( 94" ) and the DL-100.
The motor ran perfect and it actually rips the prop ( JFX 27 X 10 ) constintly when wide open in level flight.
Here is the video of my madian and you can hear, whenever I am wide open the prop rips.
Temp: 85 degress
Humidity: 58%
Pressure: 29.83
100 feet about sea level.
Video one is a run up.
http://www.youtube.com/watch?v=feA5jeS2Juo
Video two is my maiden flight.
http://www.youtube.com/watch?v=aAH8BDr33ys
< Message edited by 2robinhood -- 6/29/2008 10:03:46 PM >
(in reply to denney47)
       Post #: 201
RE: DL 100 - New Twin on the Block!! - 6/28/2008 11:07:56 PM
maxun
Status: offline
nice
(in reply to 2robinhood)
       Post #: 202
RE: DL 100 - New Twin on the Block!! - 6/29/2008 12:59:29 AM
Bob Pastorello
Status: offline
Sounds like it is COOKING!!!!! (in a good way!)
Load that puppy.... you need a 12 pitch!!!!
Very nice. (Low end is still rich)
_____________________________
Bob Pastorello www.rcaerobats.net
Learn from others...you can't live long enough to make all the mistakes yourself....
       Post #: 203
RE: DL 100 - New Twin on the Block!! - 6/29/2008 2:10:47 AM
eraser
Status: offline
Is there a user manual out there for the DL-100??
(in reply to Bob Pastorello)
       Post #: 204
RE: DL 100 - New Twin on the Block!! - 6/29/2008 2:49:05 AM
Bob Pastorello
Status: offline
My engine came with the DL50 instructions.
Probably there will be some documentation made available, but I don't think there is anything out there yet.
Anything I can help with?
(in reply to eraser)
       Post #: 205
RE: DL 100 - New Twin on the Block!! - 6/29/2008 3:07:38 AM
Josey Wales
Status: online
Bobwhat prop are you running ?
Joe
       Post #: 206
RE: DL 100 - New Twin on the Block!! - 6/29/2008 3:10:53 AM
Bob Pastorello
Status: offline
27-10 - JXF
Haven't tached it.
(in reply to Josey Wales)
       Post #: 207
RE: DL 100 - New Twin on the Block!! - 6/29/2008 3:30:03 AM
qnzkrew
Status: offline
i freaking love this engine. i just started it yesterday. what a difference to start compared to my zdz. bran new out the box 4 flips choked to get fuel in the carb. 1 flip with ignition on and choked and it popped. 2 flips and it was running . i dont have to wear out my arm like my zdz .
       Post #: 208
RE: DL 100 - New Twin on the Block!! - 6/29/2008 3:34:12 AM
Bob Pastorello
Status: offline
Yep
It's pretty easy to keep going.
(in reply to qnzkrew)
       Post #: 209
RE: DL 100 - New Twin on the Block!! - 6/29/2008 4:34:41 AM
qnzkrew
Status: offline
hey bob. i had a 7.2 volt battery with my zdz ignition. zdz will take up to 9 volts. the dl likes the 5 volts. how many miliwatts does the ignition pull. i have a 3 amp UBEC from hobbycity and i want to know if i can safely use it. i used it to start my engine for the first time and for 3 more break in runs after it using a 11.1 lipo brought down to 5 volt with the UBEC. i dont wanna have to get a 3o dollar voltage regulator if i dont have to.
       Post #: 210
RE: DL 100 - New Twin on the Block!! - 6/29/2008 11:04:56 AM
Bob Pastorello
Status: offline
If it worked on your break in start ups, it will continue working. Draws the same mah whether on the ground or in the air.
I'd try it, if it's all I had, and it already worked.
As long as the ignition is getting 6 v or less, you're good. 3A is more than enough.
       Post #: 211
RE: DL 100 - New Twin on the Block!! - 6/29/2008 12:51:40 PM
Bob Pastorello
Status: offline
Have updated my website, added a little info on the DL 100
http://www.rcaerobats.net/GAS_ENGINE_INFO/DL100_Information.htm
       Post #: 212
RE: DL 100 - New Twin on the Block!! - 6/29/2008 7:57:37 PM
denney47
Status: offline
quote:
ORIGINAL: Bob Pastorello
Thanks Bob, good information.
Not sure what it is going to be but the factory said the next release of engines will have an upgrade? I am not sure what they feel they need to change but we will see.
Tom
Valley View RC
       Post #: 213
RE: DL 100 - New Twin on the Block!! - 6/29/2008 8:11:09 PM
qnzkrew
Status: offline
hey denny i have a question. when i first started my engine i noticed black coming out of one of the spark plugs. i checked it and it was loose so i retightened it with pliers as much as i could because i dont have the tool for the spark plug. today i started it again and it did the same thing just only very little. is it still loose ? i just need to tighten it some more. and if there is an upgrade, will the current owners be avaible to upgrade whatever piece they upgraded? keep us posted
       Post #: 214
RE: DL 100 - New Twin on the Block!! - 6/29/2008 8:56:34 PM
