Jack Skip
Joined: 9/8/2003 From: Marsh Harbour, Abaco, BAHAMAS Status: offline
I would like to make the A123 plunge, but cannot figure out the setup to get as a starting point. We do not have any hobby stores nearby, so experimenting usually involves waiting 2 weeks for stuff to arrive. With a Lipo setup the online stores normaly have suggested power systems; Motor, ESC, Prop and Lipo Battery. They often also tell you expected flight times. What is the best way of "translating" these setups to a A123 setup? 1 - Use same number of A123 cells as the Lipo setup, but prop up to a larger prop. 2 - Add an extra A123 cell and prop down slightly. I would always prefer a lighter setup, but not if it becomes underpowered. I have read threads where it is suggested at least 400 square inches of wing, which suggests to me most people go for the extra cell and take the weight hit. I am looking for 3D flying. The plane I am looking at is the Great Planes Reactor Bipe, with their suggested set up; Rimfire 35-36-1200kv, E-Fly SS 45 amp ESC. 600 square inches of wing. 38 ish onces. They use 3 cell lipo and 11 X 7 prop. What would you suggest?
