Delta for a jett 90?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> Delta for a jett 90?
Page: [1]
Login
Delta for a jett 90? - 5/15/2008 5:48:56 PM
rcmaster-RCU
Status: offline
I have jett 90 with a tuned pipe and was looking for the fastest craft to put this on. I would think a delta would be the fastest, but I can't seem to find a delta in this size. Any suggestions?
Alex.
       Post #: 1
RE: Delta for a jett 90? - 5/15/2008 5:50:49 PM
evan-RCU
Status: offline
A delta is not the fastest planform but if you really want one why not enlarge plans for a smaller one? The Outlaw lends itself well as does the Diamond Dust.
_____________________________
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
(in reply to rcmaster-RCU)
       Post #: 2
RE: Delta for a jett 90? - 5/15/2008 6:08:24 PM
rcmaster-RCU
Status: offline
What is the fastest planform?
Alex.
(in reply to evan-RCU)
       Post #: 3
RE: Delta for a jett 90? - 5/15/2008 6:18:13 PM
evan-RCU
Status: offline
Regular fuse, hor and vert stabs, and a high aspect ratio wing. Look at F5D or the dynamic gliders...
Not that there are not fast deltas, but the above is more efficient.
I have Deltas too.
Click to see fullsize image.
Click for fullsize
       Post #: 4
RE: Delta for a jett 90? - 5/15/2008 8:00:48 PM
bob27s
Status: offline
Look more toward some of the late 1970's pattern aircraft.
Always a great home for FIRE-90 power.
Ask around in the Classic Pattern forum - quite a few kits remain available through various sources.
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
       Post #: 5
RE: Delta for a jett 90? - 5/15/2008 9:17:58 PM
rcmaster-RCU
Status: offline
Thanks. I will look at some pattern planes.
Alex.
(in reply to bob27s)
       Post #: 6
RE: Delta for a jett 90? - 5/16/2008 3:00:48 AM
Lomcevak Duck
Status: offline
If you really want a delta for your .91, look at the Bruce Tharpe Vortex.
www.btemodels.com
When someone loses a plane in the pits, you do a lomcevak duck.
Press Alt F4 to see my other witty line.
       Post #: 7
RE: Delta for a jett 90? - 5/16/2008 3:02:15 AM
evan-RCU
Status: offline
That's a waste for that motor, it's not designed for speed, big and thick wing...
(in reply to Lomcevak Duck)
       Post #: 8
RE: Delta for a jett 90? - 5/16/2008 2:22:41 PM
bob27s
Status: offline
Worth taking a look here too....
http://www.rcuniverse.com/forum/fb.asp?m=6693952
I think Chuck was going to make this available as a kit of some form...... eventually.
Bob
Bob Brassell
       Post #: 9
RE: Delta for a jett 90? - 5/16/2008 4:28:49 PM
rcmaster-RCU
Status: offline
I don't really need a delta just something fast to put the engine to its proper use. Would a Dirty birdy, chaos, or an epsilon be pretty quick?
Alex.
       Post #: 10
RE: Delta for a jett 90? - 5/16/2008 4:59:23 PM
bob27s
Status: offline
I took for granted you had a 90 and a pipe - I equated that to a FIRE configuration engine. Is that correct?
Kaos and derivatives are at bit draggy. Not too bad on speed with retracts on them though.
Epsilon is nice, but was designed for slower more modern pattern work.
DirtyBirdy is a good step up from the Kaos - but is not designed for a RE engine if that is what you have.
Bridi UFO would be a bit better.
For a side exhaust (some with potential for RE setups)
Tipo, Patricia, Curare, Brushfire, Intruder (glass version), Deception, T2A-1, Blue Angel lots around like that.
And if you are focusing on speed and looking for super-crisp pattern with it, take 6 or 8" off of the wing span.
If you have a FIRE setup, anything with an enclosed pipe setup, preferably an enclosed engine too would be fastest.
Something like an Aurora, LA-1, Arrow, Magic, Atlanta, Citation, eclipse, T2A-mkII. And the EU-1A can really move with a FIRE-90 in it.
If nothing else, there are more than a few Patriot XL aircraft out there moving quite nicely with a Jett 90 up front
< Message edited by bob27s -- 5/16/2008 5:10:03 PM >
Bob Brassell
       Post #: 11
RE: Delta for a jett 90? - 5/17/2008 3:12:26 AM
rcmaster-RCU
Status: offline
What does the "FIRE" stand for? It is rear exhaust with a tuned pipe. Its the exact same engine and pipe in that slipstream plane that you posted the link to if that helps. I will look into the planes you mentioned. Which one has the cleanest look?
Thanks Bob for the help.
Alex.
       Post #: 12
RE: Delta for a jett 90? - 5/17/2008 2:36:50 PM
freakingfast
Status: offline
F.I.R.E. Stands for Front Intake Rear Exhaust. Yes Chuck is running the 90LX FIRE and yes they are the cleanest engine configuration.
< Message edited by freakingfast -- 5/18/2008 1:12:08 AM >
When in doubt, give it full power. The smaller
pieces fit easier in the bag! Revver Bro #201
       Post #: 13
RE: Delta for a jett 90? - 5/17/2008 8:45:02 PM
bob27s
Status: offline
quote:
ORIGINAL: rcmaster-RCU
Alex.
Front Intake - rear exhaust. As was noted
All of the designs are different, and each has its own appeal
The Arrow would tend to be the fastest given the right setup (just a guess based on what I remember). For side exhaust... it might be a toss up.
Most of the designs I mentioned were from the ballistic pattern era .... speed = energy = big manuvers. There was no such thing a 1:1 power or 3D like you see today. So speed was used to carry the big vertical manuvers, and make the rolling manuvers long and smooth.
Bob Brassell
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
