Which engine to purchase for 35% aircraft
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Which engine to purchase for 35% aircraft
Page: [1]
Login
Which engine to purchase for 35% aircraft - 5/15/2008 7:28:24 PM
rogue313392002
Status: offline
I just bought a 35% Edge 540 and I was wondering which engine would be the best one to buy, I was debating between the DA, ZDZ, or 3W engines. The other question I have is what size would u recomend, the plane is rated for 80-100cc, cause I don't want to overpower it.
       Post #: 1
RE: Which engine to purchase for 35% aircraft - 5/15/2008 8:16:05 PM
Jake Ruddy
Status: offline
Your question is still too vague...
How much is it suppose to weight?
Are you building it stock?
What type of flying do you plan on doing?
Which Edge is it?
(in reply to rogue313392002)
       Post #: 2
RE: Which engine to purchase for 35% aircraft - 5/15/2008 8:28:50 PM
rogue313392002
Status: offline
The plane is already together w/o engine weighs 20 pounds, I'll be doing 3-D mostly, its an Edge 540T, not sure what kit it is
(in reply to Jake Ruddy)
       Post #: 3
RE: Which engine to purchase for 35% aircraft - 5/15/2008 8:58:38 PM
Jake Ruddy
Status: offline
Well DA100 or 85 are going to be both good choices.... 85 will keep it light and have more than enough power.
       Post #: 4
RE: Which engine to purchase for 35% aircraft - 5/16/2008 1:09:29 AM
Tired Old Man
Status: offline
The new BME 115. Tons of power and lighter than the 85. A little more money but you won't be needing to step up in engines if you go to a heavier airframe.
DA is a good choice as well but why settle for less than you could have? If going with the DA 100 you'd be spending the same money for less engine, more weight, and less power. If the 85 it would be less money, more weight, and less power. With a 3w 80 and would be more weight, less money, less power. With the 3w 100 or 106 it would be the same money, more weight, and less power.
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
       Post #: 5
RE: Which engine to purchase for 35% aircraft - 5/16/2008 4:01:34 AM
krayzc-RCU
Status: online
really now
smooth as silk!
(in reply to Tired Old Man)
       Post #: 6
RE: Which engine to purchase for 35% aircraft - 5/16/2008 4:49:49 AM
Tired Old Man
Status: offline
What is "enough" power?
(in reply to krayzc-RCU)
       Post #: 7
RE: Which engine to purchase for 35% aircraft - 5/16/2008 5:07:25 AM
krayzc-RCU
Status: online
Pat i need to find something for that 115 is what i am thinking
smooth as silk!
       Post #: 8
RE: Which engine to purchase for 35% aircraft - 5/16/2008 9:47:13 AM
yarom
Status: offline
If you care about proper support and service, it's hard to beat the new DA-100. It's 6oz. lighter and provides 200 more rpm with a 28x10. If you can use a lighter engine with slightly less power, the DA-85 is a good choice with a 27x10.
       Post #: 9
RE: Which engine to purchase for 35% aircraft - 5/16/2008 1:54:50 PM
TheRickster
Status: offline
My vote is 3W-106.. I have been very pleased with mine.. It has run perfect from the first tank of fuel and is only getting better...
Rick
We do not do this to save money, we save money to do this..
(in reply to yarom)
       Post #: 10
RE: Which engine to purchase for 35% aircraft - 5/16/2008 2:20:52 PM
karolh
Status: offline
The BME 115 sounds like a very good choice but have the little carb related kinks been ironed out of it.
Karol
(in reply to TheRickster)
       Post #: 11
RE: Which engine to purchase for 35% aircraft - 5/16/2008 6:09:50 PM
altavillan
Status: offline
Their website says they are in stock and shipping. Not a lot of news regarding them, but have heard they have reed block mods in place.
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
(in reply to karolh)
       Post #: 12
RE: Which engine to purchase for 35% aircraft - 5/16/2008 7:09:32 PM
Tired Old Man
Status: offline
The corrections required to resolve the old carb issues are 100% complete and in production. Every owner of one of the previous 115's can obtain that fix for the cost of shipping. The new engines will be OEM equipped with it. No worries.
I've spoken with Andy extensively over the past few weeks and everything sounded like it was good to go. Enough so that I recommended the 115 to a uas manufacturer.
(in reply to altavillan)
       Post #: 13
RE: Which engine to purchase for 35% aircraft - 5/16/2008 8:19:07 PM
yarom
Status: offline
I've had a BME. I found the company not responsive to mail, calls or anything related to service. There was also a cost associated with replacing the prop hub to one more proper for large props (six bolts). After hearing about the issues with the 115, I decided to stop using these.
They are light and supposedly powerful, but I need to able to get proper support when needed. So back to DA it was...
quote:
ORIGINAL: karolh
Karol
       Post #: 14
RE: Which engine to purchase for 35% aircraft - 5/16/2008 9:11:25 PM
krayzc-RCU
Status: online
bme has been taken over by new owners the past is the past
smooth as silk!
(in reply to yarom)
       Post #: 15
RE: Which engine to purchase for 35% aircraft - 5/17/2008 12:06:03 AM
Tired Old Man
Status: offline
Yep, the old horse is dead. To complain about what took place with the original owner while failing to note the new ownership along with imporovements being incorporated with the new line is grossly unfair.
< Message edited by Pat Roy -- 5/17/2008 6:59:55 AM >
       Post #: 16
RE: Which engine to purchase for 35% aircraft - 5/17/2008 2:43:16 AM
