JWN
TX, USA Status: offline
[QUOTE]Originally posted by Waco Driver This discussion is not taking into account the fact that since cars are operated in the horizontal position, they have a relatively constant fuel head at all times. This means that fuel/air mixture ratios are little affected between a full and nearly empty fuel tank. In an aircraft flown aerobatically however, fuel heads may change thru a range of perhaps 12 or more inches from nose up to nose down. If mixture is set slightly too lean on the ground with the model held in the horizontal position, it will be severely lean in the vertical climbing position. This is where the 18-20% oil in the fuel mix saves the day. If a model aircraft were always flown in a relatively horizontal position, say doing just circuits, with takeoffs and landings, you could probably get away with using 8-9% oil in the fuel mix also. [/QUOTE] I disagree. Ever seen how a car is worked through the corners? There are pretty severe side ways G-forces at work on the fuel system. Especially when working through S-turns. Also, what about off road buggies and trucks which are constantly being jumped and tumbled? John
