JWN
Joined: 3/26/2002 From: Florence, TX, USA Status: offline
[QUOTEPossibly true in many cases, But there are still many Plain Bearing engines where Higher amounts even with good oils is required for maximum life . [/QUOTE] Let me rephrase my statement. The vast majority of modern engines do not require 18% oil. Besides, what is 18%? Of what type, quality and amount? Is this number based on weight or volume? How do you know which was used if the jug only states 18%? On top of that, how do you know it's a high quality oil and not some generic bottle labeled "oil" pulled off the shelf of the Dollar General store? The fact is, you don't. [QUOTE Agreed, But as I indicated, Things happen , fuel lines split, gaskets leak, fuel foams, dirt blocks. IMO there are to many unpredictable things that can happen to make a blanket statment that 18% of any oil is not required , but should be[COLOR=orange]recommended[/COLOR] , and in some cases that is how it is worded. [/QUOTE] Higher oil content in the fuel is not going to do anything to prevent damage from the things you noted. All of these items can, and should be, prevented through careful installation and maintenance of your model car, boat, plane, helicopter, etc. In a properly maintained model, none of these "unpredictable" things will happen. Certainly not dirt. That's what a fuel filter is for. If you ingest dirt down the air intake, that's your fault for not running an air filter. Again, totally preventable and not unpredictable at all. John
