mesaflyer
CA, USA Status: online
Kat, The stock tail wheel mounts to the rudder with a hard wire, so any banging type abuse while trying to the steer on the ground gets transferred to ther rudder servo. I have the stock tail wheel on my Pulse, and I have the digital Futaba servos (I thought I needed them at the time) and haven't had a problem yet, knock on wood. But, I fly at a dry lake bed, so I don't have to use taxi ways, so not very much steering on the ground. Now, I have a Sullivan on my son's Tiger 60 useing the heavy spring. If the wind is blowing even a little bit, the plane won't turn on the ground. Of course, I am probably saving a servo. I don't have 20 years of experience with R/C planes, so I really can't tell you which way is best. Logic would dictate that having a rudder servo fail in mid flight would be a bad thing . I probably don't need to tell you this, but when you get your Pulse in the air take it easy for the first few flights. It is a lot easier to fly than the Nexstar, but it will not try to correct itself like a trainer will. The Pulse will go right were you point it, including straight down, in a hurry. After you get the hang of it and you are pretty sure that you are ahead of the plane, you have to try the high rates. Everything happens sooooo much faster, rolls, turns, loops. You will see what I mean. It's pretty fun. And you might want to try a few different props. I asked awhile back about props. Got some good answers here. http://www.rcuniverse.com/forum/m_6049142/mpage_1/key_Pulse%2Cprops/tm.htm I put a 12.25 x 3.75 prop on mine with the 46. What a huge difference. Have fun with your Pulse. After a few flights, you will probably wonder why you started with the trainer!
