Sound card for fsone
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Sound card for fsone Page: [1]
Login
Sound card for fsone - 5/17/2008 3:10:27 PM
NCBrit
Status: offline
So apparently fsone is not compatible with certain sound cards, and my motherboard happens to have one of the incompatible ones built in. So what cards ARE compatible? They dont tell you on the website.
_____________________________
http://www.bspringall.com/rc
       Post #: 1
RE: Sound card for fsone - 5/17/2008 6:46:01 PM
CloudSkipper
Status: offline
What is the symptom? No sound or bad sound, etc...
Did you look at the InertiaSoft faq? Apparently some "sound issues" can be fixed by trying different hardware acceleration settings. It's explained below:
http://www.inertiasoft.com/fsonefaq/#Q1014-FS1
My sound card is integrated in my mobo, so I can't suggest a separate card that works, but my mobo has an NVidia chipset for sound.
Oh and the standard advise: "make sure your sound card driver is up-to-date".
< Message edited by CloudSkipper -- 5/17/2008 6:47:31 PM >
(in reply to NCBrit)
       Post #: 2
RE: Sound card for fsone - 5/21/2008 2:32:48 AM
NCBrit
Status: offline
Mine is an nvidia built into the mobo too. I get only idle and full throttle sounds. No inbetween. I have adjusted the acceleration settings as per the faq and at the lowest setting I get a variety of different engine sounds although the transitions between the different throttle settings are not smooth. The trouble is with the hardware acceleration adjusted to none, all other windows sounds are affected.
(in reply to CloudSkipper)
       Post #: 3
RE: Sound card for fsone - 5/21/2008 9:47:39 PM
RU4JESUS2 FALCONGTS
Status: offline
ajust the sound setting down to fix is what i did to fix my cpu
ON A WING AND A PRAYER!
       Post #: 4
RE: Sound card for fsone - 5/22/2008 1:39:18 AM
CloudSkipper
Status: offline
quote:
ORIGINAL: RU4JESUS2 FALCONGTS
Do you mean turning down the volume setting within fsone?
NCBrit: I don't know whether many people have broken sound in fsone, but I'm sure it's the exception rather than a rule. The quality and compatibility of integrated sound is tied to how it is integrated with the mobo and what mobo. If I was in your situation I would just buy a new or used sound card (disable the integrated one in the hardware profile before installing). If you have a computer store with used equipment you could get one super cheap. If you were to buy a new one, would be wise to confirm that you could return it if it's not compatible.
I take it that you're aware that the drivers for your integrated sound could well be bundled with the chipset drivers for your mobo... in case you've been wondering where to look for updates for that.
(in reply to RU4JESUS2 FALCONGTS)
       Post #: 5
RE: Sound card for fsone - 5/23/2008 3:40:16 AM
RU4JESUS2 FALCONGTS
Status: offline
what i did set sound acceleration lower
MY cpu kept locking up or freeze up
in the settings on your cpu mine was a HP cpu
also is it XP or Vista??
a cheep sound card may fix the problem
       Post #: 6
RE: Sound card for fsone - 5/23/2008 12:03:15 PM
NCBrit
Status: offline
And thus back to the original question. What sound cards ARE compatible? does anyone know?
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
