blvdbuzzard
Joined: 6/16/2002 From: boulevard, CA, USA Status: offline
Do you have a pitch gauge? That will tell you if you are trying to pull to much pitch. The other thing is what is the throttle curve? What fuel and what is the nitro content? All of these will effect the way the motor runs. On the O.S. .32 the low end needle has a large effect on mixture all the way to about the 3/4 throttle. Open the low end needle a tiny bit. Get the motor started and idling, pinch the fuel line. How long does the motor run? Now, I could be wrong here, I have not thought about it for a long time. I think the stock setting are, low end 1 1/2 turns open, top end 2 1/2 turns open. I think mine was running very well at 1 3/4 turns open on the high end. I do not remember the low end setting. Dru.
