Phill86
Joined: 1/6/2008 From: Not Applicable, UNITED KINGDOM Status: offline
Hello. I am trying to set it up on a DX7 that has the settings below. motor is disconected but I was in thottle hold and not idle up. Everything is level apart from the blade grips, but that may be because of the pitch curve. I do not really understand pitch / thottle curve so I just put in the settings Casey Lamm suggested to use with the DX7. http://www.rcuniverse.com/forum/m_7464466/tm.htm I will try doing it with my DX6i and see what happens there. Thank you for your help. Throttle Curve -EXP OFF Norm L - 0.0, P1 - INH, P2 - 50%, P3 - INH, H - 100% ST-1 L - 100%, P1 - 92.5%, P2 - 85%, P3 - 92.5%, H - 100% ST-2 L - 100%, P1 - 92.5%, P2 - 85%, P3 - 92.5%, H - 100% Pitch Curve - EXP OFF Norm L - 35%, P1 - 42.5%, P2 - 50%, P3 - 75.0%, H - 100% ST-1 L - 0%, P1 - INH, P2 - 50%, P3 - INH, H - 100% ST-2 L - 0%, P1 - INH, P2 - 50%, P3 - INH, H - 100% Hold L - 35%, P1 - 42.5%, P2 - 50%, P3 - 75.0%, H - 100%
