Super Sport Trainer
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> Super Sport Trainer
Page: [1]
Login
Super Sport Trainer - 5/18/2008 8:49:42 PM
windcosmic
Status: offline
Hi! Any info about this plane? If I well rember it is a little hig wing for 051 engine
       Post #: 1
RE: Super Sport Trainer - 5/18/2008 9:25:59 PM
jjscott
Status: online
It was featured in the August 1976 RCM. Kits do show up on ebay. Here it is.
Jim
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to windcosmic)
       Post #: 2
RE: Super Sport Trainer - 5/18/2008 9:32:46 PM
windcosmic
Status: offline
Thank you very much Jim!
(in reply to jjscott)
       Post #: 3
RE: Super Sport Trainer - 5/19/2008 10:30:21 PM
SST
Status: offline
I have the 1/2A size, the .09 size ARF, .25 and .40 size, and have 96" SPAD and an 85% (of the 1/2A version redesigned into a negative stagger biplane for ACE wings) versions under construction. Love the looks, and they fly better than stick-type planes.
My avitar shows my .40-size, converted from trike to taildragger, with a K&B .61, and my 1/2A size. As you can see, I like them, a lot...
< Message edited by SST -- 5/19/2008 10:32:45 PM >
_____________________________
Rule #1: Always know when to get out of Dodge.
Rule #2: Always know HOW to get out of Dodge.
       Post #: 4
RE: Super Sport Trainer - 5/20/2008 12:10:33 PM
windcosmic
Status: offline
Do you have the plans for the .25 sized?
(in reply to SST)
       Post #: 5
RE: Super Sport Trainer - 5/22/2008 6:20:59 AM
rcdude-K
Status: offline
SST,
I have one of these as well. I bought it from Hobby Lobby about 10 - 15 years ago. Finally decided to finish it as I just got back into the hobby. I was thinking of converting it to brushless electric though, Any suggestions. How well do they fly? are theya good sport trainer do you think? Would it benefit from adding a rudder? Any input would be usefull and helpful.
       Post #: 6
RE: Super Sport Trainer - 5/22/2008 6:23:57 AM
rcdude-K
Status: offline
Or maybe it was Hobby Shack.
(in reply to rcdude-K)
       Post #: 7
RE: Super Sport Trainer - 5/22/2008 2:15:09 PM
MJD
Status: offline
quote:
ORIGINAL: jjscott
Jim
Looks perfect for a hot .15!
It's a good simple design indeed. Needs to be 16 oz or less though, IMHO, no excuse for 1-1/2 pounds with a 1/2A.
MJD
       Post #: 8
RE: Super Sport Trainer - 5/22/2008 10:45:00 PM
SST
Status: offline
My .09 size flies great on a Norvel .074 & Cox 7X3.5, but not quite enough for unlimited vertical. My 1/2A size is sporting a Norvel .061, and should also be more than adequate. While I'm not able to recommend a specific e-motor setup, it should easily work as an electric. Neither the .09 nor the 1/2A have or really need a rudder, but if you want to add one, and carry the extra weight, that's fine. They're supposed to be aileron trainers, but I used half the recommended dihedral, and it's still easy to fly and very aerobatic. Flies better (in my opinion) than a stick, and is way better looking. The K&B .61 in the .40 size is overkill, and is WAY more than enough for unlimited vertical. I usually fly it about 1/2-2/3 throttle. I also have added tip plates, and they really make it a ****cat on approach, and improve the roll rate. I have not built the .25, but after the 40 size, I think a good .25 will be great, and a .40 would be pretty wild. I can copy the plans, if you'd like one. PM me an address, and I'll get back to you. Or I'd be glad to trade a set for a set of Clancy Staggerbee plans...
(in reply to MJD)
       Post #: 9
RE: Super Sport Trainer - 5/23/2008 2:02:57 PM
MJD
Status: offline
quote:
ORIGINAL: SST
LOL - RCU blanked out the first 5 letters of "****cat". That might be a bit much. This is a test, lessee if it does it again - I have three cats, but I think the female is the cutest little **** cat of them all.
EDIT: it does! What's next, con***, crank*****, **** Tracy, Isacc Hayes as "*****", Canada's nickel has a ******* on it, **** chowder, ****ry music?
MJD
< Message edited by MJD -- 5/23/2008 2:05:33 PM >
(in reply to SST)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
