hummingbird111
TN, USA Status: offline
I have just recently built the 40. size patriot, and i have the SJ 50 in it, i think the mount holes line up the same as the OS 46 ax , i have one of those too, the problem i think you will have is the way this plane is built you will have to mount the engine in it when ever you glue in the chin block and all other nose parts. If you are putting the OS in first , you may have to do a hack job later getting the os out, and the Jett in,. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ VAROOOOM!!!>.
< Message edited by hummingbird111 -- 5/20/2008 7:05:01 AM >
