Where to get a cheap 12v power supply?
Tower Hobbies
Logged in as Guest
  Printable Version
FISHER FUEL PRODUCTS 5 GALLON & 2.5 GAS FUELERS
Seller:  hunternfla
Details:   $220.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Where to get a cheap 12v power supply?
Page: [1]
Login
Where to get a cheap 12v power supply? - 5/19/2008 11:20:26 PM
gaRCfield
Status: online
I know they're out there!
I couldn't find a computer power supply with enough amperage to make one. Radio shack here is stoopidly expensive.
_____________________________
..this hobby is doing weird things to me...
       Post #: 1
RE: Where to get a cheap 12v power supply? - 5/19/2008 11:31:56 PM
guver
Status: offline
There should be many on e-bay and for your batts , even an old one for free should do a nice job. I got a couple of old clunkers that my computer guy gave me for free and they both do about half of what the rating (200watt) is 80-100 watts.
you hear that silence?
(in reply to gaRCfield)
       Post #: 2
RE: Where to get a cheap 12v power supply? - 5/19/2008 11:37:15 PM
SavageX78
Status: offline
How much amperage do you need? A pc power supply should do it.
RCs : XXX-T MF2 ~ Xray M18 ~ Micro-T~ E-maxx 3905 ~ Mardave Cobra ~ Old Lunchbox (needs Restoration)
(in reply to guver)
       Post #: 3
RE: Where to get a cheap 12v power supply? - 5/19/2008 11:44:50 PM
gaRCfield
Status: online
I saw this on the website:
This is a Compact Switching 12V, 7A Power Supply.
***********This item can NOT be used as a power supply for the************ ********* Great Planes TRITON series or the DuraTrax ICE charger ************ ********* It does not meet these chargers' current requirements **************
Doesn't this mean I need more than 7A???
(in reply to SavageX78)
       Post #: 4
RE: Where to get a cheap 12v power supply? - 5/20/2008 1:18:10 AM
guver
Status: offline
No, you will only need about 3-4 amps.
       Post #: 5
RE: Where to get a cheap 12v power supply? - 5/20/2008 2:33:40 AM
gaRCfield
Status: online
thanks.
(in reply to guver)
       Post #: 6
RE: Where to get a cheap 12v power supply? - 5/20/2008 3:50:36 AM
RevToTheRedline
Status: offline
guver you are incorrect, these chargers are 12v DC, the whole system is DC, if the charger is 7A it needs at least a 7A power supply, if its a 10A charger it needs more than 10A.
And that's granted if the charger is 100% efficient which it's doubtful there is one in existence. If you have an Ice I'd recommend getting a 15A power supply, my recommendation would be a Pyramid PSV200 it's a nice $50 20A, I have the 30A model it's been great.
Also original poster I'm not sure what you meant by you couldn't find a computer power supply with enough amperage, before I got my Pyramid 30A I ran an old Antec 350w power supply (low wattage by todays computing standards) and it was rated at 12v 18A which would be MORE than enough to power an Ice.
< Message edited by RevToTheRedline -- 5/20/2008 3:56:20 AM >
Race on Saturday, fly on Sunday.
       Post #: 7
RE: Where to get a cheap 12v power supply? - 5/20/2008 4:29:48 AM
gaRCfield
Status: online
I just found a pile of used computer power supplies and looked at the outputs - they were like 5v/1.5a, 12v/3a, etc.
(in reply to RevToTheRedline)
       Post #: 8
RE: Where to get a cheap 12v power supply? - 5/20/2008 4:40:50 AM
guver
Status: offline
The power requirement must be figured in total power (watts) and the only time the current required matches the current delivered is when the input and output voltage is the same (chargeing an 8 cell NI or 3S lipo)
If a charger is charging a 4 volt battery at 7 amps it only needs less than 3 amps supplied by a 12 volt ps , yet if it happens to be chargeing a 40 volt battery then it'll need over 20 amps suplied by a 12 volt ps.
We really haven't mentioned a specific charger, but in the case of an ice charger the same holds true. The power input is determined by the power output or the specific chargeing job you are doing.
< Message edited by guver -- 5/20/2008 2:59:59 PM >
       Post #: 9
RE: Where to get a cheap 12v power supply? - 5/20/2008 1:34:48 PM
Red Scholefield
Status: offline
A good power supply source is http://buyreliant.com/psupplies/pyramid_power_supplies.htm
Red S.
AMA 951 Leader Member
(in reply to guver)
       Post #: 10
RE: Where to get a cheap 12v power supply? - 5/24/2008 5:05:15 AM
bluemagic98
Status: offline
http://www.newegg.com/Product/Product.aspx?Item=N82E16817709011 12V@25A $19.99 there are a zillion p/c supplies that produce huge power these days However the pyrmid supplies are regulated @ 13.8 volts tweeking a pc supply to get over 12v can involve a little soldering some p/c supplies can output 11.8v without a 10 watt resistor wired into the 5v circuit.
http://web2.murraystate.edu/andy.batts/ps/powersupply.htm
Wild Hare 540 Edge-V1/V2 DA-50 JR9303 WH Cap-232 85" Evolution 58 WH Ultimate WH SU-26
(in reply to Red Scholefield)
       Post #: 11
RE: Where to get a cheap 12v power supply? - 5/26/2008 12:31:34 PM
wswanepoel
Status: offline
Depending on what you call cheap. Look at this one if you dont want to build one from a computer power supply.
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6879&Product_Name=16A_14v_DC_Power_Supply_for_Chargers&cda=36317
Regards Bill
Remember: Nose heavy planes flies like a dog. Tail-heavy planes only fly once.
       Post #: 12
RE: Where to get a cheap 12v power supply? - 5/27/2008 5:01:10 AM
rhk
Status: offline
Got a 12 v power supply from Fry's.com. has a 3amp output. I use it along with a hobbico quick field charger, and so far no issues. Costs $ 40. Hope this helps.
(in reply to wswanepoel)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
