Help! honeybee cp2 25a esc?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> Help! honeybee cp2 25a esc?
Page: [1]
Login
Help! honeybee cp2 25a esc? - 5/20/2008 1:06:07 AM
Stingher
Status: offline
yes im a newbee. ... i just bought my first heli. (honeybee cp2) and purchased a 3900 brushless motor, 25a esc and deans connectors...all are ESKY brand. ive installed new motor with pinion. connected larger diameter blue,red, and black wires from motor to esc. my question is how do i plug in the 3wire(red,white,black) from esc into the 4in1?? my old motor pluged in with a 2wire(red,black) connector? im sure some of you pros will no what im talking about. thanks
       Post #: 1
RE: Help! honeybee cp2 25a esc? - 5/20/2008 1:39:02 AM
Gittle
Status: online
Stingher, there is not a place to plug it into. You have to open the case up and solder a connector on and stick it outside of the case. Or buy a 40.00 dollars adapter. The old connector is voltage so don't plug it in there. There is a mod out on the forums that tell you how to do it. Esky basically cut the pins off so the consumer would not plug something into them. So now you have to solder to the pins that are cut off.
(in reply to Stingher)
       Post #: 2
RE: Help! honeybee cp2 25a esc? - 5/20/2008 12:16:59 PM
Stingher
Status: offline
thanks, any idea on how i find the instructions?? what to search for? or link? id rather do it my self than spend 40 more dollars
       Post #: 3
RE: Help! honeybee cp2 25a esc? - 5/20/2008 12:27:12 PM
Gittle
Status: online
Take the reciever apart and you can see the pins that have been remove on channels 3 and 4 maybe. Not sure of the numbers but you can figure it out pretty easy. You only need the pulse wire and the ground wire not the red. Get a connector that will work with your servo and solder em in. Test it out and make sure you have it right. You have to get power while your in there also. I did find this link.
http://www.rcgroups.com/forums/showthread.php?t=565742&page=2
       Post #: 4
RE: Help! honeybee cp2 25a esc? - 5/20/2008 4:03:11 PM
Stingher
Status: offline
im lost..my 4 in 1 has all the pins on the outside available. i have ch3,4 used by servos, but ch 5 is available with pins already there. do i just plug it in to that? it will fit????
(in reply to Gittle)
       Post #: 5
RE: Help! honeybee cp2 25a esc? - 5/20/2008 4:41:00 PM
Gittle
Status: online
Well you may be lucky. If they are already there then plug it in and test is.
       Post #: 6
RE: Help! honeybee cp2 25a esc? - 5/20/2008 5:51:13 PM
Stingher
Status: offline
im sorry, i was confused..i just have a chanel 5 available..sorry! so that wont work right?
       Post #: 7
RE: Help! honeybee cp2 25a esc? - 5/20/2008 6:27:36 PM
Gittle
Status: online
Well you need to solder the wires on channel 3 to get the throttle channel. It will be the short pins. Look at the pics on the link I posted above and you will see.
       Post #: 8
RE: Help! honeybee cp2 25a esc? - 5/21/2008 12:13:20 AM
Stingher
Status: offline
ok, i soldered white wire to inside ch3. black wire to outer pin on 3. sniped red wire as directions stated. attached red and black wire from back of 4in1 to red and black of esc, then connected final red wire that was sniped to red on esc (battery side) and nothing servos set,tail motor worked,blades worked, but no motor??? not sure of the wire sniped??what could be the problem?? see below pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 9
RE: Help! honeybee cp2 25a esc? - 5/21/2008 12:20:59 AM
Gittle
Status: online
You do not want to connect the red wire from the speed control it stays disconnected. The small red one that is.
       Post #: 10
RE: Help! honeybee cp2 25a esc? - 5/21/2008 12:35:20 AM
Stingher
Status: offline
thanks for all your help! anyway, i disconnected the red wire from controller, still nothing..might be battery, im charging to full right now and will try it then. is it true it may not work with weak battery? even though everthing else works?
       Post #: 11
RE: Help! honeybee cp2 25a esc? - 5/21/2008 12:55:03 AM
Gittle
Status: online
It should work unless your battery is totally dead and if that is the case your battery is no good now. Is it a Lipo battery? The pics all look good and in the first one you have the red wire disconnected. It looks OK there and ready to go.
       Post #: 12
RE: Help! honeybee cp2 25a esc? - 5/21/2008 1:18:34 PM
Stingher
Status: offline
battery at full charge , still nothing? yes battery is esky 1500ma lipo 11.1v. well i guess im stuck? whats the part called that was 40 dollars that would take care of this?
       Post #: 13
RE: Help! honeybee cp2 25a esc? - 5/21/2008 1:37:44 PM
Gittle
Status: online
You don't really need it. You could have it on the wrong channel. Is the ESC arming. It should beep or have a light on it. I don't use esky stuff so I am not sure when it arms but, It sounds like it is not arming. Do you have it on channel 3 or 4. I will do some research and make sure which one it is. Let me know.
       Post #: 14
RE: Help! honeybee cp2 25a esc? - 5/21/2008 1:59:41 PM
Gittle
Status: online
It is definitely channel 3. You are soldered to channel 3 are you not. Also when you plug in the battery you need to make sure the throttle stick is all the way down and the trim tab is all the way down. The idle up switch should be flipped away from you (down).
