homeunt
Joined: 2/10/2008 From: Ectobicoke, ON, CANADA Status: offline
quote:
ORIGINAL: boosted180 hi. i just bought a belt-cp. with a 2100mah battery, my flight times are only about 7 minutes? the entire 7 minutes is just spent hovering, since i'm just learning and not comfortable actually flying it around yet. is this normal? i expected longer run times..... also, even with lots of right trim, the heli wants to yaw to the left. what is the fix for this? i bought this used from a friend and everything on it is stock except the speedcontroller, which is an electrifly 25amp, and t-rex blades. he helped me set it up. but i'm totally new to this so any advice would greatly be appreciated. well that's strange I get about 14~18 minutes out of my 1800mah and about 20mins out of 2250's when they are fully charged. I think your friend may have given you a battery with a crippled cell, ask him how many charges he's done with what charger. You gotta give it a slow charger every 2 runs with high speed charging. I compltely destroyed 1 lipo not doing that. It's a 2200mah and flight time is like 10 minutes which is very bad, I charged it with 0.30A rate to full up and it gave about 19 minutes flight time. Also, your payload/amount of throttle u input matters in flight. For example, my heli lifts off at 40% throttle and hovers at about 35%. throttle and that gives me about 15 minutes at least. If your heli needs about 60% throttle to lift off and 55% to hover , that means your pitch may be too negative or you got too heavy payload. It's always good to have them just below the 50's than higher.
_____________________________
This hobby is funny, if I got cash, I got no experience. If i got experience, I see a giant hole on my wallet.
