Belt CP still has death wobble
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> Belt CP still has death wobble
Page: [1]
Login
Belt CP still has death wobble - 5/20/2008 1:40:05 PM
reor
Status: offline
Hi,
Awhile back I posted a topic for some help. I had a slight crash but enough to break a blade and put a small dent in the Tail boom and bent it slightly. After reading some replies I replaced the main shaft and feathering shaft and straightening the tail boom (it was barely noticable) and tried it out. It still wobbles when you give it any kind of speed past an idle and the tail seems to buck up and down once. Also the new blade is tracking a bit off at about 60 % throttle. Anyone know if I replace the tail boom and adjust the blade tracking, will that stop the wobble, or is there more going on? Thanks
       Post #: 1
RE: Belt CP still has death wobble - 5/20/2008 1:48:30 PM
chris6414
Status: offline
Loose grips, are causing the spool up wobble and you should pick up the turn buckles for the King/Belt at Heli Direct. Best mod for adjusting the tracking.
http://www.helidirect.com/product_info.php?products_id=6360
(in reply to reor)
       Post #: 2
RE: Belt CP still has death wobble - 5/20/2008 2:19:03 PM
Fly To Chill
Status: offline
If it still has a wobble check the paddles make sure they have 0 deg. pitch on them and make sure the flybar is stright, I use to have the same problem in till i started to use cf blades.
(in reply to chris6414)
       Post #: 3
RE: Belt CP still has death wobble - 5/20/2008 6:23:00 PM
DumbDawg
Status: offline
Straight straight straight.... everything has to be straight or you get wobbles. Blade tracking and balance is another thing to watch for. Balance out your blades and like was mentioned the turnbuckles are great cause they help in fine tuning the tracking. I fact I like them so much I'm making some for my swashplate adjustments and everywhere else I can put a turnbuckle.
They take the slop out of the system as well.
The heli will wobble a bit on spool up cause the mainblades have to line up and they do this as the centrifical throws them into place.
hope this helps
happy fly'n
_____________________________
Something had better fly
(in reply to Fly To Chill)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
