Red Scholefield
FL, USA Status: offline
Jeff, Your message to me on this subject: Red, I was curious about this subject too. The destructions say it does it but gives no explanation. I emailed Tim Marks at FMA and promptly got a reply saying that it DOES indeed trickle charge. The trickle charge function only activates when using the manual charge mode and it's rate depends on the capacity of the pack. If you have one of these chargers, peak a NiCD pack in the manual mode, check the mAs put into the pack when charging is done, and leave the pack connected overnight. In the morning check the mA numbers again and you'll find that they have increased. Just thought you should know. Best regards, Jeff I did as you suggested and found that the number, mAH input stayed the same as it was when the charger completed the peak charge. 48 hours later there was no change. Also 1/100 trickle charge is not enough even to compensate for self discharge, much less bring all the cells in the pack to a full state of charge after peak. You will need at leastC/20 to top off the charge and then C/50 to sustain the level of charge. I have seen no evidence that supports that there is any trickle charge in the Ni-Cd charge mode. Here is what I'm trying now. Setting the Capacity to max (5000 mAh) this means the trickle if what we are being told is true should amount to 50 mAh. I will note the mAh input reading at the time the pack peaks and then watch it and see if there is any change over the next few hours. I will also have a peak current recording digital voltmeter in the circuit to see if there is any indication of a trickle charge pulse. Stay tuned.
_____________________________
Red S. AMA 951 Leader Member
