RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Page: <<   < prev  86 87 [88] 89 90 91 92 93 94 95   next >   >>
Login
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/2/2013 2:05 PM
badazzgti03
Score: 100
Last Login: 5/24/2013
Status: offline
Happy New year everyone!!!!
I almost have the fuse done, need to upgrade the motor mount to seat the DLE 20. gotta look for a good place to pick up that Opto kill switch. As for the wings I have got them repaired and when I beefed up the retract mounts, those survived the earlier wreck and fixed them and beefed up the area thats hold the bass wood for the mounts in. Re-doing the whole retract back. Took out the fiberglass retract cups and going to work from there. Will post up pics soon.
Hide Signatures
(in reply to Lifer)
       Post #: 2176
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/2/2013 4:14 PM
raptureboy
Score: 178
Status: online
Good thought there lifer, these things go from China in a container for days on the ocean then sit on a dock in the sun (real hot) then shipped across the country to IL. I imagine that if they shrunk the covering too tight to start with there would be issues with warping or tearing in the covering. I have found that using an iron over the heat gun gives a better result than the heat gun and helps to adhere the covering to the sheeted surfaces, and a trim iron works really good for those little wrinkled areas and air bubbles.
_____________________________
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
(in reply to Lifer)
       Post #: 2177
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 2:15 PM
cstevenpeterson
Score: 105
Status: offline
Received mine with the wrinkled covering but they seem to iron out well. The vertical stab was severely warped to port side - not shipping damage , it was built that way! Called Tower and they are sending a new fuse. Great customer service is why I keep going back to Tower.
Hide Signatures
(in reply to KaP2011)
       Post #: 2178
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 2:43 PM
raptureboy
Score: 178
Status: online
Well, mine arrives tomorrow, so wish me luck.  Sounds like these are a real hit and miss item
Hide Signatures
(in reply to cstevenpeterson)
       Post #: 2179
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 4:12 PM
KaP2011
Score: 115
Status: offline
There may be a few small issues, but all in all, I've always liked Top Flite. My TF Cessna 182 was near perfect. It still sucks that they had to go to china to get them made, but you've gotta do what you've gotta do to stay competitive. RC flyers are cheap because we know whats under the covering.
KaP2011
AMA #408493
Hide Signatures
(in reply to raptureboy)
       Post #: 2180
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 5:02 PM
badazzgti03
Score: 100
Status: offline
hey everyone here is a few pics of whats under my hatch just forward of the cockpit. I carbon fiber wrapped panels with 3m di-noc.
Hide Signatures
       Post #: 2181
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 7:20 PM
cstevenpeterson
Score: 105
Status: offline
I would agree about TF. I have been selling NIB H9 warbirds so I can replace them with TF. The P-51 was the only real issue I have had with any of their newer ARF's. That being said and aside from the stabilizer issue, the plane is fairly nice - certainly worth the price I paid with all of the discounts. If I wanted better, I would have to build it myself.
Steve
Hide Signatures
       Post #: 2182
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 8:11 PM
KaP2011
Score: 115
Status: offline
Stabilizer issue? I guess I need to get busy reading all 88 pages of this thread. My replacement wings should be here tomorrow, I'll probably start on the assembly Monday.
Drifter - I think you found the plane I remember, "Little Indian". My memory is different from the pictures but I do remember that it was the Little Indian. Thanks for the help with the pictures.
KaP2011
AMA #408493
Hide Signatures
       Post #: 2183
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/3/2013 11:55 PM
ken78cvx20
Score: 101
Last Login: 5/22/2013
Status: offline
Well so far I am two for two about the same amount of wrinkles as the last one and no damage well packed. I think I will go with the stock retracts for now with these struts looks like a good fit.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 2184
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 2:50 AM
Flight 21
Score: 100
Last Login: 5/3/2013
Status: offline
Wow those struts look very nice. I have not seen those around, what brand/size are they?
"Do or do not. There is no try." -Yoda
Hide Signatures
(in reply to ken78cvx20)
       Post #: 2185
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 3:03 AM
ken78cvx20
Score: 101
Status: offline
 Flight 21
Check out rcskylite.com
I think the 110mm P-51 set would work well with the stock retracts along with this servo.
 Spektrum A7000 Metal Gear Mechanical Retract Aircraft Servo.
Ken
Hide Signatures
(in reply to Flight 21)
       Post #: 2186
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 3:36 AM
Flight 21
Score: 100
Status: offline
Thanks!
Hide Signatures
       Post #: 2187
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 4:32 AM
I_Fly
Score: 100
Status: offline
These struts look a little short to me.   I remember the length of the stock struts being a bit longer.   Like 160mm.
quote:
ORIGINAL: ken78cvx20
Ultra Sport Brotherhood #122
Ryan STA/STM Brotherhood #5
Hide Signatures
       Post #: 2188
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 5:52 AM
ken78cvx20
Score: 101
Status: offline
  Like these
 Dimension
Hide Signatures
(in reply to I_Fly)
       Post #: 2189
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 6:17 AM
frets24
Score: 148
Status: offline
I have used these on a couple of planes in the 10-12.5 lbs range and they're great. The real life appearance of the oleo scissors is really nice.
I ended up ordering a whole range of off-set depths and have several unused/unmounted sets left over if any one wants a deal PM me, in the mean time I'll see what offset depths and strut lengths I still have.
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
       Post #: 2190
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 2:34 PM
I_Fly
Score: 100
Status: offline
That looks more like it but measure before ordering.   The wrong length could cause all sorts of issues.   As it is some modification is most likely needed to accommodate the scissor  in the wheel bay.
  Like these
 Dimension
Hide Signatures
       Post #: 2191
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 2:46 PM
KaP2011
Score: 115
Status: offline
HK has these struts that would probably work as well and would probably not require any modification to the wing.
http://www.hobbyking.com/hobbyking/store/__13270__Offset_Oleo_Leg_160mm_12kg.html
And then there are these that are about half the price of the RC Skylights.
http://www.hobbyking.com/hobbyking/store/__23892__Alloy_Oleo_Legs_Offset_P_51_Style_161mm_2pc.html
KaP2011
AMA #408493
Hide Signatures
(in reply to I_Fly)
       Post #: 2192
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 3:10 PM
drube
Score: 115
Last Login: 5/20/2013
Status: offline
quote:
ORIGINAL: cstevenpeterson
Steve
Could you explain what the stabilizer issue is. I don't recall reading about that, but I may have missed it.
My Music
http://www.reverbnation.com/tunepak/3545294
Hide Signatures
       Post #: 2193
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 3:32 PM
I_Fly
Score: 100
Status: offline
I actually ordered and received the legs from the 2nd link below.  They look and feel good but I have not put them on the plane (not sure exactly when I'll have time at this point).  One of my concerns is that the stock gear setup currently on my plane has little or no offset.  Just looking at the setup I do have some concern that the offset may cause the wheel to stick out of the wing when retracted.  Adjusting the geometry of the retract mounts may be required for any of these struts.   I'd be interested to see how some of the guys with aftermarket struts have put them in.
quote:
ORIGINAL: KaP2011
Hide Signatures
       Post #: 2194
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 3:52 PM
cstevenpeterson
Score: 105
Status: offline
My plane arrived with the vertical stabilizer warped to the port side of the plane - actually has a nice curve to it. It was not caused by shipping but was either built this way or perhaps subjected to alot temp extremes during is jouney from China to my house. As far as I know this is an islolated issue with my plane. Tower has shipped a replacement due to arrive on Monday. I'll let you know how it looks..
Steve
Hide Signatures
(in reply to drube)
       Post #: 2195
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 5:11 PM
5skyhawk172
Score: 121
Status: offline
Mine will be here today !
Hide Signatures
       Post #: 2196
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/4/2013 7:14 PM
drube
Score: 115
Status: offline
Thanks Steve.
My Music
Hide Signatures
       Post #: 2197
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/5/2013 2:06 AM
raptureboy
Score: 178
Status: online
It came  and it looks good, just the usual minor wrinkles here and there. I'm gonna store this for a couple of months until i get some of my other projects off the bench. I have a kit built P-47 that is getting scaled out and it's been sitting for the last month almost. Time to get serious now. What a deal for under $200
Hide Signatures
(in reply to drube)
       Post #: 2198
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/5/2013 3:56 AM
ken78cvx20
Score: 101
Status: offline
Just ordered a set of these going to match them up with the HK retracts that are rated for 10.? lbs and see how they do. I did measure a HK retract in the wing along with the stock 3 1/4 wheel from center of wheel to retract was 160mm with retract center on rails.
Will see
Ken
Hide Signatures
       Post #: 2199
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/5/2013 1:34 PM
LennyD
Score: 100
Last Login: 4/28/2013
Status: offline
Thanks for giving me a new wallpaper for my desktop!!
Hide Signatures
(in reply to drifter)
       Post #: 2200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.547RCU1
