RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Page: <<   < prev  86 87 88 89 90 91 [92] 93 94 95   next >   >>
Login
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/24/2013 4:29 PM
KaP2011
Score: 115
Last Login: 5/19/2013
Status: offline
Mine is completed, I'm at the point of applying the decals. I discovered that the decals don't match pictures on the box. In the pictures, the star on the side is the same size as the decal on the wing. The decal sheet does not have the correct sizes.
As for the rest of the decals that come with the plane, they are a poor example. I've decided to make my own decals for most of the plane. Earlier in the thread there is a link to a page that has the correct decals and placement for a P-51D. The same link also shows panel lines and rivet detail so I'm making my first attempt at adding panel lines.  I may do the rivet detail if this plane lasts long enough to get re-covered.
_____________________________
KaP2011
AMA #408493
Hide Signatures
(in reply to badazzgti03)
       Post #: 2276
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/24/2013 6:06 PM
badazzgti03
Score: 100
Last Login: 5/17/2013
Status: offline
yeah I agree with you on the decals they are kinda weak...ill be making my own too..i do own a vinyl cutter so that will help...but anyways my P-51 is going to be civilian..no weapons and going to have the Audi infineon race inspired colors. silver with red and black carbon fiber.
< Message edited by badazzgti03 -- 1/24/2013 10:11 PM >
Hide Signatures
(in reply to KaP2011)
       Post #: 2277
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/24/2013 8:00 PM
thebluemax
Score: 100
Status: offline
I had gotten some made by Kirby Custom Graphics.  Was not cheap but they did come out really good.
quote:
ORIGINAL: badazzgti03
yeah I agree with you on the decals they are kinda weak...ill be making my own too..i do own a vinyl cutter o that will help...but anyways my P-51 is going to be civilian..no weapons and going to have the Audi infinion race inspired colors. silver with red and black carbon fiber.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 2278
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/24/2013 10:06 PM
badazzgti03
Score: 100
Status: offline
Looks good thebluemax!!!! ill have to do some decals too
Hide Signatures
(in reply to thebluemax)
       Post #: 2279
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/25/2013 2:45 PM
raptureboy
Score: 178
Last Login: 5/20/2013
Status: offline
Try Callie graphics, she is very reasonable and already has many of the popular themes already on file in the correct scale and will customize what ever you need. http://callie-graphics.com/
This is the real task before us: to reassert our commitment as a nation to a law higher than our own.
Hide Signatures
       Post #: 2280
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/25/2013 5:04 PM
KaP2011
Score: 115
Status: offline
I'm looking for the stenciling decals. You know, "step here, aftercooler vent, that kind of stuff. From what I've found on the internet, you pretty much have to make your own.
I find it funny that TF left off the part about crew weight. Didn't want to offend anyone I suppose.
KaP2011
AMA #408493
Hide Signatures
(in reply to raptureboy)
       Post #: 2281
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/25/2013 5:58 PM
raptureboy
Score: 178
Status: offline
Try here  http://www.getstencils.com/  pricey but they have what you need.
Hide Signatures
       Post #: 2282
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/28/2013 11:07 PM
TTRotary
Score: 100
Last Login: 4/30/2013
Status: offline
Its not 100% scale like the real one but I know what you mean. I made it that way and I made my own gear doors and did not use the fiberglass ones.
May not be scale, but looks great nonetheless badazz. What door sequencer did u go with?
Hide Signatures
       Post #: 2283
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/29/2013 2:57 PM
badazzgti03
Score: 100
Status: offline
Thanks TTrotary,
I'm using the jet tronics sequencer. Been wrapping the fuse in silver/aluminum monokote. Having one hell of a time wrapping it though...Going through monokote like crazy. The wing was pretty easy to wrap. Does anyone have any options on how i should paint the canopy or what paint i should use. Only thing that comes to mind is that paint that is used for the lexan plastic for RC car/truck bodies.
Hide Signatures
(in reply to TTRotary)
       Post #: 2284
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/30/2013 3:36 PM
KaP2011
Score: 115
Status: offline
I did a search of the thread and find no mention of the M.A.C. Has anyone worked out the M.A.C.?
KaP2011
AMA #408493
Hide Signatures
       Post #: 2285
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 1:14 AM
TTRotary
Score: 100
Status: offline
thx badazz - that's a nice one - going to try my luck with the cheaper Jomar.
KaP2011 - no, but not hard to calculate on this wing. The LE jog at the fuse is insignificant, so just extend the LE line to the fuse, measure the chord, do the same for the tip, and average the two. Published CG info for this bird seems accurate - a rarity among chinese ARFs. If you want to be safe, start at 25% root chord, Not including the jog, upside down with gear retracted of course.
Hide Signatures
       Post #: 2286
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 3:09 AM
radfordc
Score: 100
Last Login: 5/6/2013
Status: offline
quote:
ORIGINAL: KaP2011
Why would you care what the MAC is? The manual gives you the correct CG location.
Hide Signatures
       Post #: 2287
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 3:25 AM
KaP2011
Score: 115
Status: offline
Mostly I was just curious. I've read in the thread that several people thought the C/G was wrong. I worked it out today on a drawing board and it worked out exactly where TF says it should. 33% of the M.A.C. is 5 5/8" from the leading edge at the side of the fuselage. Falls right on the spar.
And just because a chinese manufacturer says something in a manual does not always make it true. I have found more ARF manuals to be wrong than right.
KaP2011
AMA #408493
Hide Signatures
(in reply to radfordc)
       Post #: 2288
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 2:39 PM
raptureboy
Score: 178
Status: offline
Thats true of most of the off brand ARF's but this is a TF and they do a great job on their manuals and I've never had an issue with the C.G being wrong on any of their products. In my opinion I think people are inaccurately checking their c.g and making them too tail heavy, again just my opinion. I started using a vanessa rig to check the c.g and it works great.
Hide Signatures
       Post #: 2289
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 3:20 PM
KaP2011
Score: 115
Status: offline
One of the reasons I wanted to find the M.A.C. is because I didn't like trying to measure the C/G at the fuselage, I could only get close to where it should be. Checking the C/G at the M.A.C. eliminates the problem.
I've only assembled two TF ARF's, a Cessna 182 and this P-51. The 182 was perfect, minimal wrinkles and only one problem. That was in the instructions concerning the flap instelation. The P-51, well, it had issues. It hurt TF's reputation in my opinion.
KaP2011
AMA #408493
Hide Signatures
       Post #: 2290
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 6:04 PM
radfordc
Score: 100
Status: offline
The Vanessa rig is certainly the cheapest, easiest and most accurate method of finding the CG.
Click for fullsize
Hide Signatures
       Post #: 2291
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 6:31 PM
radfordc
Score: 100
Status: offline
I'm going to try these retracts and gear legs in my P-51.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=34110
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=23892
They work well on the bench and I've read some good reports on them: http://www.rcuniverse.com/forum/fb.asp?m=11373387
Click for fullsize
Hide Signatures
       Post #: 2292
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 8:55 PM
ken78cvx20
Score: 101
Status: offline
quote:
ORIGINAL: radfordc
I have the same setup I plan on using have you tryed them for fit yet.
Ken
Hide Signatures
       Post #: 2293
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 10:22 PM
radfordc
Score: 100
Status: offline
I pulled a wing out of the box and the retract fits OK. May need to clearance the wheel well just a little to clear the scissor link.
Click for fullsize
Hide Signatures
(in reply to ken78cvx20)
       Post #: 2294
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 10:59 PM
ken78cvx20
Score: 101
Status: offline
Hey radfordc,
Thanks for posting the picture saves me the trouble. I havn't started on mine yet still in the box but looks like I my need to stay with the 3 1/4 " tires.
Ken
Hide Signatures
       Post #: 2295
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/31/2013 11:07 PM
radfordc
Score: 100
Status: offline
These Hobbyking struts will only take a 3" tire...max.
Hide Signatures
       Post #: 2296
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 2/6/2013 3:03 PM
badazzgti03
Score: 100
Status: offline
Hey everyone!! an update and photos of the build....Finally Wrapped in silver aluminum! what a pain in the ass! Not a perfect wrap but pretty good. Going to be adding decals and red with carbon fiber accents. wings are finished and wrapped as well those were easy. Still gotta work on the cockpit and instrument dash and got the canopy taped up and ready for paint.
Hide Signatures
       Post #: 2297
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 2/7/2013 2:14 AM
YellowAircraft
Score: 181
Status: offline
Hi,
On a VERY soft version of a hard landing, both my main gear went aft and ripped the leading edge of the wing up. Everyone there was shocked at the damage given the way the landing looked. Disgusted...
Yellow Aircraft, JetCat Engines and Turn Key Jets
yellowaircraftplanesdotcom
Hide Signatures
       Post #: 2298
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 2/7/2013 3:06 AM
KaP2011
Score: 115
Status: offline
Very sorry to hear. Makes me worry about the gear on mine which has not had the maiden flight yet.
KaP2011
AMA #408493
Hide Signatures
(in reply to YellowAircraft)
       Post #: 2299
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 2/7/2013 2:11 PM
badazzgti03
Score: 100
Status: offline
Wow that sucks man....Thank happened on my wreck. Gear mounts never broke they just ripped out of the wing structure and destroyed the leading edge. I rebuilt the whole front leading edge around the gear structure, and strengthened the structure too. I do have to say this model was was built with the wrong kinda wood in the wrong places. A lot of balsa around the gear structure. Replaced it with plywood.
Hide Signatures
       Post #: 2300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.672RCU1
