RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Top Flite '.60 size' P-51D Mustang ARF: Building & Modifications
Page: <<   < prev  52 53 [54] 55 56 57 58 59 60 61   next >   >>
Login
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/6/2010 8:54 AM
Flight 21
Last Login: 5/3/2013
Status: offline
I agree with Rbean - the 90 should be more than enough. It all depends on your flying style, but he is right on about the large amount of torque and bigger props and pitch. If you have at least intermediate flying skills the SP 90 should be great.
_____________________________
"Do or do not. There is no try." -Yoda
Hide Signatures
(in reply to mimoore67)
       Post #: 1326
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/6/2010 2:23 PM
goedhartige
Last Login: 9/24/2011
Status: offline
The reason I will go for the 120 sp is the following:
The sp engines have a 2:1 gear internally, so they will turn at half the rpm of 'normal' four strokes. Therefore they need the high pitch propellers to be able to pull them through the sky. But at the same time, they are less efficient during slow flight (=take-off and landing)
Therefore I will use a 3 or 4 blade prop, so the pitch goes down again, so I will have more thrust at the low speeds, needed for those hairy situations...
(the efficiency of the 4 blade prop at the higher speeds will be less, but the mustang will be fast enough anyway, so it's a trade off between thrust at low speeds, or thrust at high speed)
My mustang will be quite heavy as well: I have century jet retracts, on board glow, droptanks, 10 HVAR rockets, maybe smoke system,...
(I think the 90 sp will be enough if you just have the stock set-up, without any mods)
BUT IMAGINE THE LOOK OF THE BIG 4 BLADED PROP :-) quite scale...
Hide Signatures
(in reply to Flight 21)
       Post #: 1327
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/7/2010 12:22 AM
CorsairJock
Last Login: 3/30/2013
Status: offline
The 90SP will swing a 4 blade also.
And speaking of torque: I have noticed that this plane seems to want to maintain that left turn right after after takeoff more than any other warbird that I have flown. I'm holding right rudder, but it still yaws and rolls left every time it takes off. The condition was worse when I had the 4 blade prop installed (more torque), which is why I went back to the 2 blade props.
People that are set on over-powering their warbirds will do so regardless of anyone else's opinion, so if your so sure you can handle the extra torque: go for it.
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
Club Saito Member #670
Hide Signatures
(in reply to goedhartige)
       Post #: 1328
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/7/2010 2:22 PM
goedhartige
Status: offline
Well, I still didn't buy the 120 sp, so I'm still able to switch to the 90 sp or cd...
CorsairJock, do you think the 1.20 will be overpowering the plane, with all the extra's I will put on the plane? (CJ retracts, on board glow, droptanks, accu monitoring, etc.)
I just want that extra oompff if I need the power... and thought that the .90 would be only 'just' enough...
I just want a nice flying bird, not one with bad habits due to the bigger engine...
any advice? (I now have the rcv 90 CD installed... maybe I don't need to switch to the bigger one? )
Hide Signatures
(in reply to CorsairJock)
       Post #: 1329
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/7/2010 8:15 PM
RBean
Last Login: 5/16/2013
Status: offline
I'm leaning towards the RCV 90SP. The airframe seems pretty light. The Spring Air retracts, Robart struts and wheels are on order and won't be too heavy. I'm concerned about the weight of the 1.20. At 34 oz it is almost as heavy as the gasser (38 oz). Do the RCV SPs need an on board glow driver? That would be more weight with the extra battery.
Hide Signatures
       Post #: 1330
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/7/2010 11:56 PM
CorsairJock
Status: offline
I hate to make judgements concerning engines that I have no practical experience with. Altho I own an RCV 90SP (as well as a 60SP), I have never even 'fired it up' My intentions are to install it on a Thunder Tiger F8F Bearcat, but it is another one of my projects that has been put on the back burner. That Bearcat should weigh a little over 10 when completed (with 3 gear retracts, functional flaps), and I have every reason to believe that it will be a good engine for it (especially with a 4 blade prop).
I'm thinking you Mustang will end up in the 11 lb range with the 90SP, and again: I'm thinking it should be enough to fly it comfortably and scale. It won't be a skyrocket/ able to leap off the ground and go straight up vertical, but you should get a reasonable climb without too much torque issues. Just my opinion. And despite what some people say: warbirds DO fly better/ easier when they are lighter. Not only do they fly better, they impose less stress on the landing gear, and I have witnessed that even CenturyJets are not indestructable.
Hide Signatures
(in reply to RBean)
       Post #: 1331
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/10/2010 9:00 PM
sandseeker
Last Login: 5/18/2013
Status: offline
My TF P51, YS 91 Slimline pitts and Century retracts. Flew today nose heavy despite lead in the tail...great flying plane!
Anyone fitted gear doors to CJ retracts?
Chris
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by sandseeker -- 1/11/2010 3:30 PM >
Hide Signatures
       Post #: 1332
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/12/2010 12:08 AM
RBean
Status: offline
I've decided to go with a .91 FS to keep this thing light. I'm using 700 series Spring Air retracts. I have Spring Airs in a VQ Hurricane with Robo struts and 3.5" wheels. They work great. However, with the Mustang I want to use the off set struts, but the Spring
airs take 3/8" robo struts and the largest wheels these size robo struts take is 3.25 ". The 7/16 Robo Struts take 3.5" wheels, but won't fit the retracts. I'll be flying off a grass runway so the larger the wheels the better. Any one flow this plane off grass with 3.25" inch wheels or smaller? How does it do?
Hide Signatures
(in reply to sandseeker)
       Post #: 1333
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/12/2010 12:13 AM
bucho
Last Login: 4/21/2013
Status: offline
110 OS, 125 SAITO OR 91 ONLY IF IS YS...
MY TWO CENTS.
Hide Signatures
(in reply to RBean)
       Post #: 1334
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/12/2010 3:33 AM
CorsairJock
Status: offline
quote:
ORIGINAL: RBean
I've decided to go with a .91 FS to keep this thing light. ............
Sounds like a wise choice.
quote:
ORIGINAL: RBean
................... I want to use the off set struts, but the Spring airs take 3/8'' robo struts and the largest wheels these size robo struts take is 3.25 ''. The 7/16 Robo Struts take 3.5'' wheels, but won't fit the retracts. I'll be flying off a grass runway so the larger the wheels the better. Any one flow this plane off grass with 3.25'' inch wheels or smaller? How does it do?
If you would take the time to read some of the early posts, you will find that I am using 3 1/2" Dave Brown wheels on 3/8" dia. offset RoboStruts. It took a slight modification to the struts, but I pulled it off. Otherwise, I;m sure that there are plenty who are using the stock (3/14" wheels) and having good success on grass runways.
Hide Signatures
(in reply to RBean)
       Post #: 1335
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/13/2010 4:11 AM
RBean
Status: offline
CoursairJock,
Thanks for the the info. I have read the entire thread but its been some time ago. I've ordered the 3/8" Robart Struts. I have 3.5" Robart tires so I'll find your prior post re the strut modification. I have a OS .91 Surpas II so I hope it will be enough power for at least scale like flying. I thought about the RCV .91 SP but I think I'll just go with the engine I have.
Hide Signatures
       Post #: 1336
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/13/2010 8:11 AM
rc34074
Status: offline
quote:
ORIGINAL: RBean
I've decided to go with a .91 FS to keep this thing light. I'm using 700 series Spring Air retracts. I have Spring Airs in a VQ Hurricane with Robo struts and 3.5'' wheels. They work great. However, with the Mustang I want to use the off set struts, but the Spring
RBean - if you call Spring Air they will make you adaptors so you can mount 7/16 oleos to their 700 series retracts. Hope this helps.
Ed
"there are fighters and there are targets"
Hide Signatures
(in reply to RBean)
       Post #: 1337
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/14/2010 12:48 AM
RBean
Status: offline
I called. Their adapters as I understand it use a wire between the retract and strut. So then, why use Robo strut ready retracts. I'll go with the 3/8" struts. As I have already found with my Hurricane, the robo strut ready retracts and robo struts solve a lot of problems. Also the 3/8" struts weight slightly less than the 7/16" ones. I like the spring airs because you don't have to worry about having enough air pressure to get the gear down, wether from a leak or multiple operation of the gear in one flight.
Hide Signatures
(in reply to rc34074)
       Post #: 1338
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/14/2010 3:24 AM
rc34074
Status: offline
Who did you talk with there? When I called I asked the lady who answered that I wanted to talk to the guy who makes the retracts (I think its her husband). I told him I didn't want the adaptor you are describing and he said they would make one from aluminum rod with one end sized to insert into the hole in the 700 retract and the other end of the same piece of aluminum would be sized to fit into the hole in the 7/16 oleo strut. He said to use adhesive (super glue) to keep the adaptor in place in the oleo (I figured I woul use something a little more positive than the super glue).
Sorry I didn't explain this in my first message.
Ed
Hide Signatures
(in reply to RBean)
       Post #: 1339
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/14/2010 4:20 AM
goedhartige
Status: offline
Man man man... quite a bit of work when you want more 'scale' retracts and covers...
Here is what I have so far.... now just a bit more tweeking, paint and filler...
Oh yes, you guys all convinced me that I would keep the .90 engine in it... the more scale flying, the better!
A question: does anyone has a good solution for mounting the droptanks? the system with the screws is bound to fail on the first flights, I do not intend to make them functional, only detachable on the ground...
And what about weathering ? is it possible on this type of covering? or will it just drip off?
Happy flying!
Jens
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1340
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 4:34 AM
RotorWing Nut
Status: offline
great job on the custom full length doors. I was thinking about doing the same thing as I never liked how the original was so tough to properly fit to robart struts.
The attachment to look scale. As a friendly suggestion, don't forget to add some flat blk paint to the airscoop for authentic looks.
:0
Enjoy!
-J
Club Saito member #721
Hide Signatures
       Post #: 1341
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 6:53 AM
stang151
Last Login: 5/17/2013
Status: offline
Ok,, Flight Report... My -51 was one of the first batch with great covering and the mod. needed on the retract bays. I just got her in flying condition in Dec. and maidened it on the 31st of Dec.
What can I say, the bird is perfect, better than I could have imagened when I started. The take-off roll was managable with input of rt. rudder ,it started to nose over but was more a function of it being out of trim. The climb out was positive if not spirited. Tucked up the gear and after a few clicks of trim the game was on.
With the Saito 1.00 it is no racer but the performance is better than scale. With the stock set up on the controls the loops can be nice and big and the rolls nice and crisp. Knife edges well ( pulls to the belly somewhat) I have not seen that annoying tail wiggle that some warbirds have.
Deploying the flaps does not require any trim change and slows the plane down very nicely. The landings were almost non events (except for the knee nocking) the Mustang setteled down at a nice speed and I was not uncomfortable with it at all.
After 6 flights on this plane I can say I like it alot! I met all of my goals on the build and it turned out well. I know it's just an ARF but I still like it .
Eng... Saito 1.00 , APC 14X8 prop ,Mc Daniel on board glow , Keleo inverted pitts muffler
Raido..JR 9303 2.4 , Hitec servos
Retracts... Lado 90*, Robart Robostruts/ 3 1/4" wheels
C.G. 5 1/4" from wing /fuse join
Weight... 10.8 lbs.
Mods ... Scratch cockpit sunshield ,instrument pnl. , gunsight , airbrushed pnl lines/ weathering, Slimline pilot
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by stang151 -- 1/19/2010 7:18 PM >
Gravity is just a state of mind
Hide Signatures
(in reply to RotorWing Nut)
       Post #: 1342
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 7:03 AM
stang151
Status: offline
A couple of in progress shots. I desided to do the curent warbird and make the mods on the scheme rather than take off the fin fillit to make it the WWII bird. The stars& bars and the tail nos. are Major Decals, the invasion stripes are Monokote. The guns are alum tubing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to stang151)
       Post #: 1343
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 7:07 AM
stang151
Status: offline
Couple more
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1344
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 7:12 AM
stang151
Status: offline
Last
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1345
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 7:50 AM
RotorWing Nut
Status: offline
Lemme be the first to say.......... AWESOME!! Love the airbrushing and the cockpit details! Glad your flights were heartpounding.
I see a hint of gapseals in the control surfaces.. a great added touch to detail and aerodynamics. I did the same and it covers up the robart hinges nicely.
I can't wait to get mine back in the air as soon as it warms up. A -51 on skis doesnt cut it! LOL I need to learn how to airbrush and I will do the same to mine one day. How did you do the panel lines- taped off or pen?
Congrats!
-J
Hide Signatures
       Post #: 1346
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 8:38 AM
Flight 21
Status: offline
Most excellent! Bravo! I like your choice to do the current bird - looks just like it. So did you clearcoat the plane after the weathering, panel lines and paint? Or did you use fuel proof paint on the details?
Very nice additional details. Very impressive...
Hide Signatures
       Post #: 1347
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 5:31 PM
stang151
Status: offline
Thanks,, The bird was a lot of fun. Taped off the pnl. lines and sprayed with Pactra R/C car paint, weathering also. Clear coated with Lusterkote clear (gloss over alum, flat over the colors). Did not put gap seals , mabye I should.
< Message edited by stang151 -- 1/15/2010 6:50 PM >
Hide Signatures
       Post #: 1348
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 6:35 PM
Flight 21
Status: offline
Excellent. I like the gray panel lines much better - more scale look. So with the clearcoat you used Lusterkote right out of the can?
Hide Signatures
       Post #: 1349
RE: Top Flite '.60 size' P-51D Mustang ARF: Building & ... - 1/15/2010 6:48 PM
stang151
Status: offline
Yes . It's the only Lusterkote I spray ,the color stuff not much good out of the can. I hear some people have good luck with the color but not me. This plane was a lot of fun and I learned a lot. Started looking around for the next one.
Hide Signatures
       Post #: 1350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.391RCU1
