RE: EXI 450 thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SAB Goblin 770 Helicopter - RTF
Seller:  mariogonzales
Details:   $2,500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> RE: EXI 450 thread
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: EXI 450 thread - 11/30/2008 10:46 PM
DumbDawg
Score: 100
Last Login: 7/17/2009
Status: offline
I ordered another two from Xheli... That makes three now that I'll have.. These are great machines for the price... Esky's entry market heli's in the 450 size... they have done a fine job with this heli but there are a few weak points to be aware of.... The tailbox being the most prominent of the problems... Its very weak so plan on getting a replacement tail unit for backup.... I bought an aluminum tailbox from $20 and it works fine and comes with a belt for a backup too...
For an extra $100 on top of the price I have one EXI thats near fully aluminum head and tail.. the only things I need now to complete the head are main blade grips and a flybar ends.... But these can wait as they are not as crucial to the heli's performance... They fly pretty sweet without the aluminum but its even smoother now with better responses... gotta luv it... That and the fact that parts are available from other sources than Align make this a cheap, well flying heli... you can't go wrong...
happy fly'n
_____________________________
Something had better fly
Does throwing your heli count as flying??
Hide Signatures
(in reply to noobflyer01)
       Post #: 101
RE: EXI 450 thread - 12/1/2008 11:00 AM
Friday_2006
Score: 100
Last Login: 6/10/2010
Status: offline
I had this heli too, and did everything wrong with it, until i got it retired. I wanted to stay low on cost. For this reason everything was cheap on it. It cost me 200$ to get it flying. BUT... I had this severe problem with the tail case which didn't want to stay put, always making the belt loose. I changed that with the metal align one, but then i couldn't make the tail hold. I had a real pain in the ass trying to fix that, but with no success. I retired it and keep on flying my Mini Titan. I also have a Beam E4 now, which is a great quality heli. Now, with a litlle more experience on helis i would say that my EXI had an issue with the tail belt, i don't know if i am 100% sure, but i guess belt was the problem for not holding the tail.
Anyway... I think EXI would make a wonderful birthday present for a friend ;-)
Keep Flying
Hide Signatures
(in reply to DumbDawg)
       Post #: 102
RE: EXI 450 thread - 12/1/2008 5:48 PM
noobflyer01
Score: 157
Last Login: 5/21/2012
Status: offline
the exi i have has the metal bushings on the boom mount block. i had no issues with locking the boom so my belt stays tight. since its metal to metal contact did you loc-tite the screws?
My EXI had no issues whatsoever from the first time building and setting up. Followed finless bob videos on the trex450v2 build made it real easy. i even bought the exact same gear finless bob was using in his build.
what were you using for gyro and tail control? check out page 2 of this thread and you'll see i discuss about what electronics i put in it
< Message edited by noobflyer01 -- 12/1/2008 5:51 PM >
Trex 550e FBL - Scorpion 4025-1100kv -18T , CC ICE100, CC bec pro, Mikado Mini-Vstabi , DS610 cyclic, DS650 on tail.
Hide Signatures
(in reply to Friday_2006)
       Post #: 103
RE: EXI 450 thread - 2/3/2009 8:26 PM
sonicj
Score: 107
Last Login: 5/26/2012
Status: offline
my dad gave me one of these to build up and most likely quickly smash. i want to build it up on the cheap! heres what i have access to:
exi 450
align rce-bl25x
mystery red bl motor, unknown kv (came from a 400 heli)
telebe gr201
spektrum AR6100e
zippy 2200 3s 20c
dx6i
im considering hxt900 servos all the way around (plus some backups) since they seem like the best bang deal. not taking into account the unknown motor size, does this setup sound adequate for a noob learning to hover? thanx!
Pro-Pulse B-100, Pro-Pulse T-100, HPI Micro RS4, Losi JRX-Pro SE, Losi Micro DT, Associated Monster GT 4.6, EXI 450
Hide Signatures
       Post #: 104
RE: EXI 450 thread - 2/3/2009 8:34 PM
DumbDawg
Score: 100
Status: offline
sonic... yah ur style'n on that... its cheap but not so cheap you won't be able to fly it...
Friday... did you try putting some loctite on the boom itself??? This is a cheap and easy fix too... the loctite sets up and hold the boom pretty good... what I do is scuff up the boom and block a bit with sand paper... I go circular which is opposite the slide direction and then use a little loctite to really hold it... Or do what others do as well... use some boom servo clamps and clamp it right at the block to hold the boom from slipping... same issues with the K2...
happy fly'n
Hide Signatures
(in reply to sonicj)
       Post #: 105
RE: EXI 450 thread - 2/3/2009 9:34 PM
noobflyer01
Score: 157
Status: offline
sonic, that setup is a bit weak but i guess for hovering purposes it would be ok. i can tell you that the tail control is going to be a concern. you will constantly adjust and readjust. you'll need a better tail servo than the hxt900. since it works the hardest if you can get one good servo put that sucker on the tail. for cyclic should be fine but they will strip in a crash. you can change it but its a pain in the butt. i love my hs65mg's. in fact everybody who has ever gotten them has like them. you will not hear one single negative about it. these things are tough!
your power train should be fine for hovering and a little beyond. watch your headspeed. you need to find out what kv rating it is for the motor. also the max watt.
and use this calculator for headspeed. http://dhrc.rchomepage.com/calc.htm too low of a headspeed makes the tail weak and hard to control.
< Message edited by noobflyer01 -- 2/3/2009 9:35 PM >
Hide Signatures
       Post #: 106
RE: EXI 450 thread - 2/4/2009 4:23 AM
sonicj
Score: 107
Status: offline
thanx for the great info guys! im familiar with the 65mg... they are a popular upgrade for the buggies i run. if i can swing it, i'll put one on the tail. i think its going to have to wait though as i believe the esc has some sort of issue. it powers up and programs fine, but when i bring up the throttle, the motor acts like only 2 legs are attached. it spins backs and forth with little to no power. i don't kow if the esc is under warranty or not...
i tested the motor on my car esc and all is well with it. i can't seem to find any info on it though... my dad says its a "cool red" from hobby lobby, but again, i can't find it.
is there a decent, cheap esc and/or motor from hobbycity?
Hide Signatures
       Post #: 107
RE: EXI 450 thread - 2/4/2009 5:57 AM
DumbDawg
Score: 100
Status: offline
You could check out dealextreme as they often have motor\esc combo's cheap and work fine...
good luck on send'n anything back to hobby lobby... Also if you want a place to order some 65hb's for $20.00 let me know and I'll send yah the link...
cheers
Hide Signatures
       Post #: 108
RE: EXI 450 thread - 7/31/2009 5:07 AM
FlyRC4aHigh
Score: 100
Last Login: 1/31/2013
Status: offline
Hello, Lets keep this thread going. I did something really stupid. but I guess it worked out. I'm into the Hirobo Shuttles. But I wanted a small electric to fly in the back yard. So I've been looking at the HK450 by Hobby King and thought it would be a cheap start. Well the other day I came accross a 450 which Had an orginal Align canopy on it new and had blades and motor . Well the price was great so I jumped on it. Well later while looking for servos ,esc , battery, I found out I was stupid and earlier did not look past the canopy other that the nice aluminum frame. To my suprise I BOUGHT A CLONE. it was an EXI 450. Well I think i broke even but didnt get the real bargan I was hoping for. I did discover that this EXI 450 appears to be a lot better then the HK 450. So right now I'm in the process of still finding servos, esc , batteries etc for it. Any current advise out there , Love to hear it.
Hide Signatures
       Post #: 109
RE: EXI 450 thread - 7/31/2009 6:12 AM
noobflyer01
Score: 157
Status: offline
The EXI450 is a great heli. I just bought another one last week and having a blast flying it.
Are you looking for servos to get you by or something a performer that's going to last?
cheap option:  tower pro SG90 for cyclic servos.  $5 each at   http://www.xheli.com/topromisesg9.html.  g401b (futaba gy401 knockoff)  $36 at www.xmseller.com,   get a nice quality tail servo like the futaba 9257 for $60 at helidirect.   hobbywing 40a esc  http://www.flyhelirus.com/servlet/the-348/HobbyWing-Pentium-Brushless-ESC/Detail,  and a flightmax 2200mah 3s lipo  http://www.flyhelirus.com/servlet/the-1390/ZIPPY-Flightmax-2200mAh-3S1P/Detail
if you want something with a better performance and durabilty then change out the SG90 cyclic servos for Hitec HS65Mg servo  http://www.helidirect.com/hitec-hs65mg-micro-servo-universal-connector-p-2280.hdx
the cheap gyro should be fine for you to start with....but there are lots of really high end gyros you should be upgrading once you get the hang of things.
Hide Signatures
(in reply to FlyRC4aHigh)
       Post #: 110
RE: EXI 450 thread - 8/1/2009 1:16 AM
noobflyer01
Score: 157
Status: offline
Here's some pics of my EXI450 reborn.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 111
RE: EXI 450 thread - 8/1/2009 10:34 PM
noobflyer01
Score: 157
Status: offline
YeeHAW!   Just came back flying my EXI 450.        What an awesome flying machine!   Forgot my camera so didnt get any video of it.   Batteries are charging now and will defintely do a video tommorrow.   Still tune folks....video to come soon.  but here's more pics for now.
Hide Signatures
       Post #: 112
RE: EXI 450 thread - 8/1/2009 10:41 PM
noobflyer01
Score: 157
Status: offline
enjoy
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 113
RE: EXI 450 thread - 8/1/2009 11:27 PM
noobflyer01
Score: 157
Status: offline
alrighty lets talk about my settings on the dx6i for this bad boy.
but first list of equipment:
JustGoFly 500TH w/ 13T pinion,  Align 35a esc, hs65mg's on cyclic, gy401+9257 on tail, flightmax 2200mah 25c 3S,  align 325D carbon fiber blades.
according to the calculator i'm getting 2935 rpm on headspeed with the throttle curve a flat 100% on idle 1.
swashplate mix for the pitch is at 75% for -10,0,+10   (edit) i just measured with my pitch guage and its actually -11,0,+11
swashplate mix for the aileron and elevator is at 75% for +9 degrees of cyclic.    so swash mix is  75,75,75.
normal throttle curve is at 0,70,80,90,100
pitch curve normal is at  42,46,50,75,100
stunt mode throttle curve is at 100,100,100,100,100
pitch curve for stunt mode is at  0,25,50,75,100
no weights are used on the flybar.
please note that these settings are for more advanced flying.   you may need to change your settings for a more mild ride.
< Message edited by noobflyer01 -- 8/2/2009 6:57 AM >
Hide Signatures
       Post #: 114
RE: EXI 450 thread - 8/2/2009 12:28 AM
S_Mackey
Score: 100
Last Login: 9/6/2009
Status: offline
Hm. I just received a DX6i and which trigger is used for stunt mode? Can you give me your base settings. This is my first time flying an EXI450 or any CCPM for that matter.  I am not looking to do any 3D for a long while. Just use it as a park flyer for now and learn how to fly it well. I really don't need anything really agressive for flight.
I purchased.
EXI 450 standard (Here)
HXT900x5 1 Extra (8/4?)
Volcano 30Aesc  (8/4)
Exceed RC Alpha 400 Brushless (3500kv) (8/4)
G401B Gyro (Here)
Radio System
DX6i (Here)
AR6100E (8/6)
Batteries
2x XMHobbies 2200mah 11.1 18c/25c (Here)
Thunder AC6 Charger (8/4)
Is the HXT900 usable at all for the rear tail if I am just using it as a park flyer? If I am going to have problems I can switch it but I would really like to get this flying by next weekend. And I would like to fly with what I have now. Also is there any extra parts I need? I bought these general parts above but is there anything else misc I need?
I have a Falcon40 and I thought it was a good time to step up.
Airplanes, Helicopters, UAVs, 1/8 Scale RC Buggies, 1/10 Trucks
Hide Signatures
       Post #: 115
RE: EXI 450 thread - 8/2/2009 6:34 PM
noobflyer01
Score: 157
Status: offline
Mack, the switch that activates the stunt mode is the on the upper left side of the tx.   Its the one label 0,1  and F Mode on it.   0 is normal and 1 is idle up.    Look at my pictures above.  the front servos goes in from the inside.   the front left servo I used as the aileron servo(ail). and the front right is the pitch servo (aux).  these two are interchangable and can be programmed either way.  The rear servo is the elevator servo, mounted on the outside of the frame and must go into the elevator channel (elev).
the tower pro servos may run in a different direction then my hs65mg's so use your reverse channels accordingly to get them go in the proper direction.
while the sg90 is good enough on the cyclic for the beginner its not nearly enough as a tail servo.   you may find that using this servo for tail may results in unwanted drifts.   This is where you going to have to spend some money.   Get the futaba s9257 and you'll be pleased.
use the same pitch curves i listed above.  use the same throttle curve I listed for normal.  When you are ready to fly in idle up mode set your idle up curves to something like 100,90,85,90,100.
Use your flybar weights to slow your cyclics down.   try a 11T pinion for a lower headspeed.   move up a pinion as you get more comfortable.  Note that as your headspeed is increased so is the responsiveness of your heli.
try a swash mix of  70% on Pitch,  60% on elevator, and 60% on aileron.   as you improve increasing these values will increase the amount of cyclic degrees and pitch degrees.
Hide Signatures
(in reply to S_Mackey)
       Post #: 116
RE: EXI 450 thread - 8/3/2009 10:53 PM
noobflyer01
Score: 157
Status: offline
my brother went with me to the park and shot a video of the EXI 450 today.   Sadly i'm still trying to figure out a way to convert  VTS and VOB into mpeg4.   I wonder if videmo supports my format?    anyone with any ideas?
Hide Signatures
       Post #: 117
RE: EXI 450 thread - 8/4/2009 8:28 PM
noobflyer01
Score: 157
Status: offline
I just got it all figured out on the video conversion.     here's the link for the video of the EXI 450 in action.
the first 4 minutes is the EXI and the next 4 minutes is the trex500esp
< Message edited by noobflyer01 -- 8/23/2009 9:14 PM >
Hide Signatures
       Post #: 118
RE: EXI 450 thread - 8/8/2009 8:05 AM
S_Mackey
Score: 100
Status: offline
Did anyone have an entire extra bag of screws after building the kit? Some of the parts in the kit weren't the best fit. The paddles weren't the best fit. One side seemed to be tapped wrong and did not go on straight.
Hide Signatures
       Post #: 119
RE: EXI 450 thread - 8/8/2009 6:11 PM
noobflyer01
Score: 157
Status: offline
yes, i also had a bag of screws from the exi kit.   I'm using the stock paddles on mine.   while screwing the paddles in i made sure that they went in straight.   but a new pair of paddles is very cheap.   There's more slop on the EXI than a  Trex....but nothing bad at all.    I'm using the stock frame and head.....everything else is align.
Mack, Its very important you tear down the entire heli.   My head came out of the factory with 2 washers on one and none on the other.
 Check and  make sure they install the thrust bearings correctly too.  Put grease on the thrust bearings and loctite.  Do go over the tail assembly as well.
Hide Signatures
       Post #: 120
RE: EXI 450 thread - 8/8/2009 6:31 PM
S_Mackey
Score: 100
Status: offline
Yea I figured it could have been my fault the paddles didn't go on correct. I am usually good with this stuff. I did check a bunch of other stuff and found the pitch to be at -4 or -6 at what was supposed to be 0 pitch.
I have to tear down the entire head? I wanted to get this flying today.  Which thrust bearing are you talking about? Not the one way bearing. I did a quick once over to check for loose parts but i did not check the tail yet.
Which washers are you talking about?
Hide Signatures
       Post #: 121
RE: EXI 450 thread - 8/8/2009 10:22 PM
noobflyer01
Score: 157
Status: offline
Yes Mack,  the head MUST be taken apart and reassemble.  I have included a picture of the thrust bearings.   you have to grease the middle bearing ,  put grease on the side that is concave.  i just used white lithium grease since that's all i could find.  you can buy them at a hardware store.  they must be reassembled correctly as they are each different.  Do the same thing for the tail. but the tail will be easy since you only have to check the screws holding the tail rotor grips and the one set screw.  all must be loctited.
Click for fullsize
Hide Signatures
       Post #: 122
RE: EXI 450 thread - 8/9/2009 9:15 PM
noobflyer01
Score: 157
Status: offline
I went to my LHS and got some goodies for my EXI 450.  picked up a pair of light align paddles, 14T pinion, and a new dampners.
the headspeed is absolutely insane!     will do a video this weekend with the new setup.   Headspeed calculator is giving a headspeed of 3279
Hide Signatures
       Post #: 123
RE: EXI 450 thread - 8/10/2009 12:16 AM
FlyRC4aHigh
Score: 100
Status: offline
Hello, Still looking for servos etc for my EXI 450 a couple of questions?
Told an HS-81 would be a good tail servo, would it be a good servo for cyclic etc?
Want to mount gyro under tail boom, possibly a 401 , 500t, or a telbee, looking at it the tail rod may be to long, and might interfer, is it? how do you adjust it?
Hoping to go to IRCHA this week to check things out
Fleet
EXI 450, nothing instralled yet
Hirobo Shuttles, Senior Telemaster,T-28,Hanger 9 Miss America,Harrier 46 3D(For Sale)
Hide Signatures
       Post #: 124
RE: EXI 450 thread - 8/10/2009 5:59 AM
grawyl
Score: 112
Last Login: 10/27/2011
Status: offline
Hi Guys, Its been a while but I'm back. I have been going through some personal $ht and had to let the heli's sit while I straitened things out.
The last time I touched my EXI was months ago and right after I got a really hot Kv3800 motor and crashed on a side in landing. Anyway, I went to Xheli and it doesn't look like they sell parts anymore for EXI. I can get a whole new heli but not just the parts to fix what I need to fix. I will most likely get a bare bones $29 version but I am wondering about the plastic swash. My existing swash is showing signs of age and not as precise as I like it.
Has anybody used the new plastic/metal swash on the cheep version of the EXI? This may have been covered erlier in this thread or in Crash's thread but I am feeling to lazy to search.
There is an art to flying an RC Helicopter. The art lies in learning how to throw it at the ground and miss.
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.438RCU1
