Servo % range
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Weatronic Support Forum >> Servo % range
Page: [1]
Login
Servo % range - 5/21/2008 4:01:25 AM
Edgar Perez
Status: online
Hello
What is the range of servo % value, for the position, in the log file?
I see some negative and positive values. I though servo were capable of about 120 degrees total. Can't match it to the log file numbers.
_____________________________
Edgar Perez
Puerto Rico
       Post #: 1
RE: Servo % range - 5/21/2008 7:42:22 AM
gerhardp
Status: offline
Hi Edgar,
there are slight differences between servos of same and different manufacturers. center position is 0. plus and minus 100 % relates to average specified travel of the servos being like 45 degree per side. Depending of the make and model of the servos you have different max ranges available. The pink area above and below the 100 % mark in the servo configuration window is to be used with caution, to make sure that you do not go to the limit of the servos and run them against the mechanical limit. If you do, you will most likely harm or destroy the servo.
Gerhard
(in reply to Edgar Perez)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.188RCU1
