N3N-3 Yellow Peril
Tower Hobbies
Logged in as Guest
  Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $99.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Scale Aircraft >> N3N-3 Yellow Peril
Page: [1]
Login
N3N-3 Yellow Peril - 5/21/2008 6:41:49 PM
red1
Status: offline
I am looking for plans and or kit for the Naval Aircraft Factory N3N-3 float plane (primary trainer). There was a squadron of these based at the US Naval Academy, Greenbury Point, Annapolis, MD for a number of years. I would like to build an RC 1/5 scale model. Any help in locating a source would be greatly appreciated. Thanks.
red 1 (aka Don Borton)
AMA IMAA
Waco Brotherhood #72
       Post #: 1
RE: N3N-3 Yellow Peril - 5/21/2008 10:22:07 PM
timothy thompson
Status: offline
had a ride in one and was allowed to pilot the aircraft several years ago. very nice ride
(in reply to red1)
       Post #: 2
RE: N3N-3 Yellow Peril - 5/22/2008 4:13:40 AM
fliir
Status: offline
Don:
The bad news is that I have looked for years. I have only found one plan, and it is hardly scale. I can send it to you if you want. It is also posted on the thread mentioned below.
I want to build one in 1/5 or 1/6 myself, although it is well down in my list of projects. My dad was a crew chief for N3Ns at Great Lakes NAS during WWII. I have a bunch of data including a set of blueprints, an erection manual and a photoshoot that I did at the Kalamazoo Aviation History Museum. Let me know if you need anything.
There is an N3N thread, started by Flicka5 with comments by FokkerAce (the thread was mistakenly put in the "3D" forum). FokkerAce said he was planning to design one about a year ago. You may want to PM him
http://www.rcuniverse.com/forum/m_624803/anchors_624803/mpage_1/key_N3N/anchor/tm.htm#624803
David
_____________________________
On the board: Torres 20% T-34C
Future: Navy N3N, Aeronca 402, Blohm&Voss BV-141, Heinkel HE111Z, Dornier 335
(in reply to timothy thompson)
       Post #: 3
RE: N3N-3 Yellow Peril - 5/22/2008 1:10:08 PM
red1
Status: offline
David, Timothy
Thanks for the reply. I'm former Navy, originally from St. Joseph. MI. Went through Basic at Great Lakes NTC. Spent some time at The USNA, Annapolis 1951-52. I could look out my 4th floor window in Bancroft Hall across the Severn River and see some of the 35 N3N-3s in the water or on the ramp. Never forgot them. I understand thay have one on exhibit at the Smithsonian Air & Space Museum in Virginia.
David, thenks for the lead to FokkerAce et al. I will definitely drop them a PM.
If anything new develops re the N3N-3 float plane, please let me know.
AMA IMAA
(in reply to fliir)
       Post #: 4
RE: N3N-3 Yellow Peril - 5/22/2008 1:27:32 PM
TFF
Status: offline
The one at the Smithsonian is at the Udvar-Hazy hanging up. You need to visit. I went last summer. The Smithsonian probably has raw data that you could use to make your own plans as you seem passionate. A Stearman conversion would be the way to go if it does not have to be "perfect" as no one else would ever know.
(in reply to red1)
       Post #: 5
RE: N3N-3 Yellow Peril - 5/22/2008 2:45:05 PM
CoosBayLumber
Status: offline
I have the plan and magazine of the Yellow Peril from a very old edition of M.A.N. but it does not mention anything about a float plane version.
Wm.
www.mybloo.com/coosbay/laser/laser.html
Thousands of Laser Cut parts, thousands
(in reply to TFF)
       Post #: 6
RE: N3N-3 Yellow Peril - 5/22/2008 3:10:13 PM
red1
Status: offline
TFF
Timely suggestion. Just so happens I put a "passionet" letter in the mail about an hour ago to the SASM Director of Aircraft Restoration Let's hope something usefull comes back.
AMA IMAA
(in reply to TFF)
       Post #: 7
RE: N3N-3 Yellow Peril - 5/22/2008 4:05:58 PM
red1
Status: offline
Wm
Depending on which source you look into, there were some 800 or 900 of this AC built... 100 of which were the float plane version.
AMA IMAA
(in reply to CoosBayLumber)
       Post #: 8
RE: N3N-3 Yellow Peril - 5/22/2008 6:04:59 PM
Chad Veich
Status: online
Yanks Air Museum in Chino, CA has a very nice one on display as well. Photo by Chris and taken from the WIX forum.
(in reply to red1)
       Post #: 9
RE: N3N-3 Yellow Peril - 5/23/2008 4:42:43 AM
timothy thompson
Status: offline
rides 100 for an hour . pilots get to fly in air . plane is in mt pleasant mi. Anyone wanting a ride in an authentic unmodified n3n pm me for info. need to be under 220 lbs and able to climb in the cockpit. period seat belt and instruments. all documentation is available including military logbook. Original engine. i got a chance to take her off as i have a tail dragger ndorsement. really surprised the guy belived me without seeing any pilots licnce from me
(in reply to Chad Veich)
       Post #: 10
RE: N3N-3 Yellow Peril - 5/27/2008 1:51:20 PM
red1
Status: offline
Hi Tim,
I assume (hope) your N3N ride was in the land plane version, since an FAA Single Engine Sea (SES) certification would be required for the float plane version.
AMA IMAA
       Post #: 11
RE: N3N-3 Yellow Peril - 5/27/2008 6:29:01 PM
timothy thompson
Status: offline
yes you are correct
(in reply to red1)
       Post #: 12
RE: N3N-3 Yellow Peril - 6/11/2008 7:25:07 AM
n3njeff
Status: offline
Hey all, glad this thread is still going strong!!! We have had our N3N since 1969!!!!!
There were 816 N3N-3's built. All of them COULD have floats. Just unbolt the gear and install the floats. Dont need it as a float plane, pick it up, remove the floats and re-install the gear!! RED, our N was one of the airplanes you watched out your window!!!!! If anyone needs help, you can e mail me at
vtdeucedriver@yahoo.com
Click to see fullsize image.
Click for fullsize
       Post #: 13
RE: N3N-3 Yellow Peril - 6/17/2008 2:15:08 PM
red1
Status: offline
Hi Guys,
I received a reply from the Smithsonian National Air & Space Museum Archives. They have available the following on the N3N-3:
Drawings on Paper:General Three View Landplane (31x59); General three View Landplane (22X43); Inboard Profile - side elevation (21x61); General Three View Seaplane (22x48). Drawings range from $4.90-$9.10. Complete pkg $25.20 + S/H.
Engineering drawings on microfilm: 2 rolls. Also available: printed index to above. Rolls are $30 ea, index is $2.40.
I suspect no one has a microfilm reader/printer at home, but most public libraries have one available
If you are interested, drop a line to Smithsonian Institution, PO Box 37012, NASM, Archives Division, Rm. 3100, MRC 322, Washington, DC 20013-7012. They will do the search and send you an information/purchase package. They will not accept an order unlass accompoanied by a signed/dated Document Use and Indemnification Agreement, which they include in the pack.
I have ordere all the paper drawings. I'll let you know what they look like after I receive and review them.
AMA IMAA
WACO Brotherhood #72
(in reply to n3njeff)
       Post #: 14
RE: N3N-3 Yellow Peril - 6/19/2008 2:58:19 PM
naval flight officer
