HOW TO REGULATE THE AMOUNT OF SMOKE OIL ???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> HOW TO REGULATE THE AMOUNT OF SMOKE OIL ???
Page: [1]
Login
HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/22/2008 3:26:11 AM
paco ritter
Status: offline
Got a Don Harris smoke pump on my 40% EDGE and I can empty about 32oz of smoke fluid in just a minute or so. How do you regulate the amount of smoke fluid that goes into the mufflers? Much of the oil is not being used, just shot thru the mufflers and is creating much residue on the bottom of the plane. Using SmokeDri Fluid. Have heard of placing a wheel collar on the tubing and controlling the amount of fluid by tightening the set screw, which will make the tubing hole smaller, of course. Does this go on before or after the pump? PACO
       Post #: 1
RE: HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/22/2008 3:42:49 AM
Bob Mitchell
Status: offline
I can't answer whether it will work or not, but I can tell you that it's never good to restrict the inlet of a pump. Put it on the discharge if you do it.
_____________________________
Bob Mitchell AMA 903015
H9 Alpha 60/Evolution 61NT, Sig 4* 60/OS 75AX, Futaba 7C 2.4GHz
(in reply to paco ritter)
       Post #: 2
RE: HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/22/2008 3:01:53 PM
3D_Junkie
Status: offline
Here is a link to the manufactures instructions.
http://harrismodelproducts.com/Smoke_Pump_Instructions.html
       Post #: 3
RE: HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/25/2008 1:28:11 AM
safeTwire
Status: offline
You can make a fluid regulator.
A piece of wood dowel about 1 or 1 1/2 inches long and about 3/4 to 1 inch in diameter. (Piece of broom handle) Drill through from end to end and tap for 1/4-20 nylon wing bolt. Drill through from side to side for your size oil line. Round/smooth end of nylon bolt, so it won't cut into oil line tubing.
Basically, it's the same principle as the wheel collar, except IMO the nylon bolt is "easier" on the oil tubing than a set screw.
You can mount the entire assembly on the fuselage side if you wish.
Install on the smoke oil feed line which is AFTER all other components, and connecting into the muffler.
Hope this helps
Click to see fullsize image.
Click for fullsize
(in reply to 3D_Junkie)
       Post #: 4
RE: HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/28/2008 3:53:42 AM
paco ritter
Status: offline
Hey Guys, thanks for all the comments, all were helpful. I'll try them out, starting with the end point adjustment since I am set up on a separate switch for my smoke system, not throttle regulated. If that don't do to suit me, I'll build the "wheel collar" restricter system, put it down wind of the pump and see what happens.
(in reply to safeTwire)
       Post #: 5
RE: HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/28/2008 1:48:22 PM
tkilwein
Status: offline
Make sure the outlet tube is secure or you may blow it off and have fluid all over inside.
Seen this before, made a mess of his plane.
       Post #: 6
RE: HOW TO REGULATE THE AMOUNT OF SMOKE OIL ??? - 5/30/2008 2:28:19 AM
wifpwcf
Status: offline
i mate i run mine threw my gear ch & have 3 setings on my 9x flight mode switch.
great way to do it,,here is my 42% edge SMOKE ON
cheers glen
http://www.youtube.com/watch?v=OD0DLvU85wI
Click for fullsize
Click for fullsize
TEAM AUSTARS,TEAM TO MUCH FUN CLUB
TEAM BIG COURAGE DIAMONDS
(in reply to tkilwein)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
