dx-7 program mix help
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 P-51 Mustang and JR Transmitter - RTF
Seller:  kmac425
Details:   $280.00   |  9/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Twin & Multi Engine RC Aircraft >> dx-7 program mix help
Page: [1]
Login
dx-7 program mix help - 5/22/2008 12:22:42 PM
kantina2005
Status: offline
hello again from greece.i have one dx-7 and i have mix the throtles but i trim oneby one.anyone know thank you for your time
       Post #: 1
RE: dx-7 program mix help - 5/22/2008 9:35:48 PM
kantina2005
Status: offline
does anyone knows?
(in reply to kantina2005)
       Post #: 2
RE: dx-7 program mix help - 5/23/2008 1:15:23 AM
kiosk
Status: offline
I have the same problem, I created a program mix for my twin engine using THR channel for right eng and AUX2 for left engine and it works ok, but the TRIM on the throttle only trims the THR channel, doesnt trim AUX2...which sucks cause cant turn AUX2 channel engine off!!!
Hopefully someone help
       Post #: 3
RE: dx-7 program mix help - 5/23/2008 7:35:25 AM
kantina2005
Status: offline
no to me trim both engines but cant trim one by one.and i think that maybe work
(in reply to kiosk)
       Post #: 4
RE: dx-7 program mix help - 5/23/2008 7:16:24 PM
ian51291
Status: offline
hi guys to have the throttle trim on both channel you have to mix the channels on mix 5 or 6 then it will trim both at the same time
       Post #: 5
RE: dx-7 program mix help - 5/24/2008 4:21:21 PM
mrbassman
Status: offline
If you didn't put retracts in the plane, just mix the throttle to the gear switch, so when you hit the gear switch it will close the throttles and shut down the engines, if you have it mixed the ian51291 described.
(in reply to ian51291)
       Post #: 6
RE: dx-7 program mix help - 5/24/2008 6:18:55 PM
kantina2005
Status: offline
no i dont have problem to mix i have problem to make one by one trim so get the both more close to work together
(in reply to mrbassman)
       Post #: 7
RE: dx-7 program mix help - 5/26/2008 8:12:23 AM
ian51291
Status: offline
if you mix the throttle with aux2 then inhibit the channel but activate the trim you can use the small trim switch next to aux 2 switch on transmitter
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
