Best engine, G-62 or Brison 4.2??
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Best engine, G-62 or Brison 4.2??
Page: [1]
Login
Best engine, G-62 or Brison 4.2?? - 3/12/2002 7:13:24 AM
SECRET AGENT
Status: offline
Ok warbird guys (and gals if applicable), what is the better choice for my Ziroli P-40...a G-62 or a Brison 4.2???? Let the debate begin!
       Post #: 1
Best engine, G-62 or Brison 4.2?? - 3/12/2002 11:47:58 PM
STUKA BARRY
Status: offline
SORRY SECRET AGENT, BUT THERE IS REALLY NO DEBATE. YOUR COMPARING APPLES TO ORANGES. A 3.7MAG CANT COMPETE WITH A 4.2 ELECTRONIC. ALTHOUGH ITS TRUE THAT BOTH ENGINES WILL FLY A ZIROLI P-40, WHAT EXACTLY ARE YOU LOOKING FOR IN AN ENGINE? PRICE? RELIABLILTY? FUEL CONSUMPTION? EASE OF STARTING? PERFORMANCE? THESE ARE IMPORTANT QUESTIONS.
_____________________________
KEEP UM FLYIN
(in reply to SECRET AGENT)
       Post #: 2
Best engine, G-62 or Brison 4.2?? - 3/13/2002 3:22:11 AM
SECRET AGENT
Status: offline
Sorry Stuka, I guess I shoulda been a little more specific. I really was only looking for gripes with one engine over the other. (personal preferences) Such as, "I have had more trouble with the ---- on my Brison" or vise versa. I am just looking for a feel for the two engines good or bad. I understand the differences in them, power, options etc.., just wanted to hear from the guys who go out there every weekend with the things. Thanks!
       Post #: 3
Best engine, G-62 or Brison 4.2?? - 3/13/2002 5:51:48 AM
Vince
Status: offline
Both are fine engines, within their limitations. The G62 is a rock solid performer, unless it's been abused. It is prone to bending the crank easily. Sometimes as easily as as a nose over prop strike will bend it. Likewise the Brison is also a rock solid performer, but the two cannot be compared. Both will give long years of service if taken care of. Neither is prone to any failures or problems as far as I am aware of. About the only problem you have with a gas engine is usually carb related, which can be traced to dirt.
Vince
       Post #: 4
Best engine, G-62 or Brison 4.2?? - 3/13/2002 6:21:33 AM
SECRET AGENT
Status: offline
Thats exactly the sort of stuff I was looking for, does the Brison have a stouter crank shaft???
       Post #: 5
Best engine, G-62 or Brison 4.2?? - 3/13/2002 7:00:48 AM
Big_Bird
Status: offline
Yes, the Brison has a stouter crank but it is more expensive if you have to replace it. The parts prices are quite reasonable on a G-62 and very readily available through the Horizon web site.
If money is no object, and you really want sparkling performance then why not put a Brison 5.8 or ZDZ80 in it. The P-40 has a really big cowl that would accommodate one of these engines.
If you get serious about this model and if it shows a one piece wing then I can show you how to build a three piece wing for easy transportation. I did this on my Ziroli Corsair.
Ken
       Post #: 6
Best engine, G-62 or Brison 4.2?? - 3/13/2002 7:31:19 AM
SECRET AGENT
Status: offline
Hey Ken,
I am absolutely serious about building the Ziroli P-40 and I love the thought of a three piece wing. Where do you fly at, maybe we could meet and talk. I will be at the jet meet this weekend at the racetrack. I am gonna bring my hot rod little A-4 and my big ugly Mig-29. Thanks for the help.
Mike
       Post #: 7
Best engine, G-62 or Brison 4.2?? - 3/13/2002 9:39:04 AM
Big_Bird
Status: offline
Mike, check your e-mail.
Ken
       Post #: 8
Best engine, G-62 or Brison 4.2?? - 3/14/2002 3:59:58 AM
Vince
Status: offline
The G62 suffers from an easily bent crank because it has no front support bearing at the end of the crank near the prop. The prop extension puts the prop way out in front of the foward support bearing. Also the G62 crank is pressed together, so when it bends, it really doesn't bend (unless it gets smacked real hard) it just twists out of alignment. Most of the other purpose built gas engines have a crank support system similar to a modern glow engine with a front support bearing right behind the prop.
Vince
       Post #: 9
Best engine, G-62 or Brison 4.2?? - 3/14/2002 7:22:34 PM
SECRET AGENT
Status: offline
Thanks Vince,
If you bend it, is it a mother to replace??
       Post #: 10
bent cranks??? - 3/15/2002 8:49:43 AM
bentwings
Status: offline
If you bent your G-62 just send it to RCIGNITIONS and he will fix it right and relieve you of less than a fill up of your suburban!!!!!
Had mine done and it never ran better!!
bentwings
bentwings
       Post #: 11
Best engine, G-62 or Brison 4.2?? - 3/15/2002 9:26:22 AM
Big_Bird
Status: offline
I'll ditto that. Ralph (rcign) did a good job on my crank.
       Post #: 12
Best engine, G-62 or Brison 4.2?? - 3/15/2002 9:31:21 AM
SECRET AGENT
Status: offline
[QUOTE]Originally posted by Big_Bird
I'll ditto that. Ralph (rcign) did a good job on my crank. [/QUOTE]
Hey, I thought we were talking about engines here, leave your crank out of it. HA HA
       Post #: 13
Big_Bird - Ken - 3/24/2002 11:14:35 PM
BentBalsa
Status: offline
Big_Bird
Ken
I am interested in knowing how this is one is done as I am in the process of building a wing and would like to transport it easier.
Would the choise of a Brison 69cc be equal in performance to the G-62cc. Does the 69cc have the bearing supported in the front.
JR
       Post #: 14
3 Piece Ziroli Corsair Wing - 3/24/2002 11:26:46 PM
Big_Bird
Status: offline
Glad to JR, check your e-mail.
The Brison 69cc (4.2) is rated at 7.5 hp
The G62 is rated at 4.75 hp
Brison may be a little optomistic.
Not sure about the bearing.
Ken
< Message edited by Big_Bird -- Mar 24 2002 6:36PM >
       Post #: 15
Page:   [1]
Page: [1]
