Viper Thottle Servo Placement
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> Viper Thottle Servo Placement
Page: [1]
Login
Viper Thottle Servo Placement - 5/23/2008 1:06:51 AM
YUKONFLYR
Status: offline
Where would be the best place to put the throttle servo if I were to use Hitec 225's on the elevons and a 85 for the throttle. I would also like to use a CG tank and that would occupy the forward position.
_____________________________
My Speed Demon made me do it!!! <Possessed since 1968>
Revver Bro 178
       Post #: 1
RE: Viper Thottle Servo Placement - 5/23/2008 1:18:46 AM
Fxrs_tim
Status: offline
I moved the normal throttle servo tray back a bit in the fuse to clear my tank (Jett 6oz slim). I went ahead and did this (although I shortened the tray a bit) to provide structural strength in the forward fuse area. I then mounted my throttle servo just aft of that. I used a couple of short basswood rails to mount my servo on. You need to watch and make sure that your aileron servo clears the throttle servo.
I use JR MN48 servos in the back, a HS225 for the throttle, a 270 mah nicad pack, and a 7 channel Airtronics rx. I put the battery and rx in the main fuse compartment (under the wing) and had the balance come out perfectly. Weight was exactly 3 lbs 12oz.
(in reply to YUKONFLYR)
       Post #: 2
RE: Viper Thottle Servo Placement - 5/23/2008 1:22:28 AM
doug115
Status: offline
Place the throttle servo in front of the elv/rud servos all behind the wing. Use a good Sullivan cable and tube with a ball link to the carb, a lighter but perfect servo for the throttle is the Hi-tec 81 vs the 85. A Jett 6 oz. slim tank fits in the cg location with a small amount of fitting. Doug 115
       Post #: 3
RE: Viper Thottle Servo Placement - 5/23/2008 2:36:51 AM
Ed Smith
Status: offline
Does this answer the question? Here can be seen everything, the elevator servos, the throttle servo just ahead of them, the switch, Reciever, battery and tank on the CG.
Ed S
Click to see fullsize image.
Click for fullsize
< Message edited by Ed Smith -- 5/23/2008 2:37:34 AM >
(in reply to doug115)
       Post #: 4
RE: Viper Thottle Servo Placement - 5/23/2008 3:03:26 AM
Giant
Status: offline
I use a Jett oval cg tank and a Hobbico mg 12 micro servo in the forward compartment stuck to the side with servo tape. Works great many flites with no problems.
       Post #: 5
RE: Viper Thottle Servo Placement - 5/23/2008 3:44:39 AM
garys
Status: offline
The biggest problem I see with that is section 8, paragraph g, of the AMA pylon rules. It states "Rubber grommets shall be used on all servos designed to accept them." I would interpret this as meaning the servo can't be servo taped to the fuse side. While it's just the throttle servo, I'd still rather see more protection from vibration than the tape gives.
GS
(in reply to Giant)
       Post #: 6
RE: Viper Thottle Servo Placement - 5/23/2008 12:32:05 PM
Ed Smith
Status: offline
Nice catch Gary, I like it.
Ed S
(in reply to garys)
       Post #: 7
RE: Viper Thottle Servo Placement - 5/23/2008 3:53:09 PM
daven
Status: online
Just put the rubber grommets in the servo, it doesn't say they need to have a screw go through it
Just take two small square pieces of hardwood, and glue them to the side of the fuse and mount the servo to it through the screw holes.
Dave Norman
klasskote.com
supertrc.com
(in reply to Ed Smith)
       Post #: 8
RE: Viper Thottle Servo Placement - 5/23/2008 6:03:05 PM
garys
Status: offline
Dave...I only quoted a portion of the rule...here's the entire paragraph.
"g. All screws holding the servos to the servo rails or trays and holding any trays to the airframe shall be in place and secure. Rubber grommets shall be used on all servos designed to accept them. If the heads of the servo mounting screws are small enough to pull through the grommets, washers shall be used to prevent this."
GS
(in reply to daven)
       Post #: 9
RE: Viper Thottle Servo Placement - 5/23/2008 7:19:20 PM
daven
Status: online
It still doesn't say that a screw has to be used to secure the servo.
Dave Norman
klasskote.com
supertrc.com
(in reply to garys)
       Post #: 10
RE: Viper Thottle Servo Placement - 5/23/2008 7:40:19 PM
garys
Status: offline
Ok. So with that logic, since it only says "screws" must be secure, so if tape is used for servo mounting, it doesn't have to be secure? Maybe I'll start tying my servos into place with kite string
GS
(in reply to daven)
       Post #: 11
RE: Viper Thottle Servo Placement - 5/23/2008 9:26:11 PM
Ed Smith
Status: offline
Dave, the operative part here is "Shall be in place" Not maybe, or if used, but "Shall"
Ed s
(in reply to garys)
       Post #: 12
RE: Viper Thottle Servo Placement - 5/23/2008 9:47:13 PM
daven
Status: online
It does not say that there has to be screws, but if you do use screws, they need to in place and secure.
Dave Norman
klasskote.com
supertrc.com
       Post #: 13
RE: Viper Thottle Servo Placement - 5/23/2008 10:02:16 PM
garys
Status: offline
Ok, the same terminology is used regarding engine mounting, so I take it that it's legal to tape the engine on as well? I really don't care regarding the throttle servo, but it is the way I read the rule.
Actually here's a rule that many people have failed to adhear to, even myself.....
Section 8, paragraph C. "The radio receiver and battery pack shall be surrounded by soft foam rubber or other vibration-dampening material and adequately protected against contamination by engine exhaust, raw fuel, or fuel residue."
Since going to FASST 2.4Ghz receivers, I've been servo taping 1/4" foam to the receiver and then attaching it to the fuse side with velcro. The rule states it "shall be surrounded by soft foam rubber....." Mine haven't been "surrounded", they've just had the foam between them and the fuse structure.
GS
(in reply to daven)
       Post #: 14
RE: Viper Thottle Servo Placement - 6/1/2008 7:40:40 PM
BUDMAN27
Status: offline
Oh Boy here we go. Maybe we should all show up to the next race with a aterny.
(in reply to garys)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
