Ed_Moorman
FL, USA Status: offline
Just for information, in the Model Airplane News .61 engine shootout, the only prop the OS .61FX out turned the OS .65LA was an 11-7. I have 2 of the OS .55AXs and they are excellent engines. Lots of torque and they will turn fairly well. Jett Engineering has tested their tuned muffler on the .55 and gotten good results. Their favorite prop is the 11-6. I tached the 11-6 APC on my bench with both the stock and the Jett mufflers and showed a 1,700 rpm increase (12,800-14,500). This is on 10% Omega castor blend fuel. I gained 1,500 on an 11-7 APC. The sweet spot for the 55 seems to be in the 14,000-15,000 rpm range and not up in the 16's. I only gained 800 rpm on a 10-6. The 55 was really made to over power a .46 size plane or fly a small .61 sized plane. For a true .61 sized plane, forget the older .61FX and get the newer .75AX. All the FXs will be gone sooner or later just like the SFs were. The engines will last a long time so you really should go will the newer model.
_____________________________
Ed Moorman, AMA 553, KD4QBM, Revver Bro #156 R/C Report Magazine, Fun Aerobatics Column
