rotarydoc
MD, USA Status: offline
Hey Nick, Sounds like you did have a blast! Good for you! Glad you got to meet some people and got to fly a plane, sounds like it was fun! Glad the damage to the CPP was minimal... I got to fly today for about 2 minutes. I realized right away that it was not the motor at all. While I was flying I realized that it would lose altitude only with right aileron. I got it back to the bench, and thought I found the problem. The servo arms had a lot of play in them, like in the geartrain of the servos. So, I packed it all up, and went home with it. Got it all apart, I had new gearsets already, from when I ordered 4 sets. I put in the new gearsets, and something went way wrong with one of them. It just sat there an buzzed, and would not move. I thought I had it bound up somehow, but I couldn't see anything wrong. I had another spare servo, that needed gears, so I put gears in it, and tried it, and it seemed OK. Then, I put everything back together, and tried it. No luck at all. The servo arms still have the same amount of play in them, even with new gears. After much observation, I realized what is happening. If I slowly give it right aileron, the left rear servo (aux) which is the only one that does not have excessive play, moves fine....but the right rear servo (aileron) does not move right away along with it. This results in the swash being lifted, changing the main blade pitch, thereby, my altitude problem. I tried using my spare DX6i, to eliminate the radio, and it was the same. I can watch it on the monitor, and it all looks good. I am going to have to assume that I have at least two bad servos, as they just don't seem to be right. Not only do they have too much play in the arms, but they don't seem to react as they should compared to the newest one that has no play. I am wondering if tomorrow, I can substitute the old servos from the B400 temporarily, not even mount them, just plug them in and watch how they react to inputs. I am pretty frustrated with it tonight, have been working on it since I got off work. I guess I'll price some new Eflite servos, I can't see spending alot of money on good servos for the CPP... Hope you have a great day flying tomorrow as well! I think I am going to concentrate on the B400...I always get frustrated with the way the CPP flies... Talk to ya soon, Glenn
