H.O.B kits any good?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> "1/2 A" & "1/8 A" airplanes >> H.O.B kits any good?
Page: [1] 2   next >   >>
Login
H.O.B kits any good? - 5/25/2008 6:24:25 AM
skyraider71
Status: offline
Has any one built the H.O.B. Spacewalker or Decathelon? Did ya like it?
I'm looking for small sporty model in .09-.15 size.
_____________________________
Busting props, and shredding Mono-cote since 1999
       Post #: 1
RE: H.O.B kits any good? - 5/25/2008 5:18:18 PM
mtntopgeo
Status: offline
Bought the Spacewalker kit. Opened it up & started to put stuff on the scale. Guestimated that the completed plane (with Enya .09 power) was gonna be 32+ OZs. Put the stuff back into the box, & the box far back up on the shelf. It's too easy to just order another Mini Super Sportster. (About 19+ OZs with the .09). ....................... George K.
< Message edited by mtntopgeo -- 5/25/2008 11:35:54 PM >
(in reply to skyraider71)
       Post #: 2
RE: H.O.B kits any good? - 7/1/2008 3:59:42 AM
rbeluche
Status: offline
I built the Force One many moons ago and I liked the kit. It went together well and the die cutting was great. It was not too heavy, but then the balsa in the kit was not flimsy either. It flew very well with an OS 40 bushing motor. Had to have the stock muffler pointing towards the nose of the plane as it requires a pusher configuration, but no problems with performance, just a bear to fight ground effect upon landing, which needed to be slightly on the hot side. Originally had an airtronics 4ch but someone talked me into using a FUTABA, PTUI,PTUI. INterference caused a tragic attempt at boring a hole to China. SOB, sniff BOO HOO!!!
Frank
Honey, I'm home! I brought some more toothpicks too!
(in reply to mtntopgeo)
       Post #: 3
RE: H.O.B kits any good? - 7/1/2008 2:03:27 PM
LaCerne
Status: offline
House of balsa kits are great and fun to build. Balsa USA kits are nice too, just finished a Force One, but HOB kits are from a different company. I've built the Chea-Pass Float plane .10, Chea-Pass Stick .10, and the PT-19, with Saito 30. All fly very well and none are heavy. I've also got the Spacewalker in kit form as well as the P-51 .25, and a 2x2 glider. All of their kits are very well made and designed. The instructions tend to be good if you've built other kits before.
Have Fun!
Larsen
AMA 93432
(in reply to rbeluche)
       Post #: 4
RE: H.O.B kits any good? - 7/1/2008 6:14:17 PM
rainedave
Status: online
The old HOB kits are what Sig would call "Craftsman Kits." The boxes contain a bunch of balsa blocks that must be shaped my hand. Personally, I love creating mounds of wood shavings on the floor. But, if you want a quick build the Ace Simple Series is probably a better choice.
Here's a HOB ad from the 12/79 RCM; the kits have been around for a while.
David
Click to see fullsize image.
Click for fullsize
(in reply to LaCerne)
       Post #: 5
RE: H.O.B kits any good? - 7/1/2008 8:51:33 PM
fritzke
Status: offline
Dave,
Thanks for reminding me that I am missing that Pete kit!
I'm with you, love to carve them blocks of balsa! Beats vac-formed
plastic any day. Of course, the fuselage tops of all those warbirds
ARE vac-formed plastic.
Dave
(in reply to rainedave)
       Post #: 6
RE: H.O.B kits any good? - 7/1/2008 9:36:35 PM
rainedave
Status: online
That's right, I almost forgot about the fuse tops. I liked the way they printed plans on both sides. My Chipmunk had the Bonanza plans on the back. I sold it before ever even starting it. Now, I wish I still had it.
David
(in reply to fritzke)
       Post #: 7
RE: H.O.B kits any good? - 7/1/2008 9:51:59 PM
longdan
Status: offline
Those wing loadings are quite high compared to what we would consider a 'normal' 1/2A loading for a .049 today. I guess the RC gear of the day is to blame for the excessive weight. I'm sure the same kits would turn out quite a bit lighter with micro RC gear.
       Post #: 8
RE: H.O.B kits any good? - 7/1/2008 9:56:18 PM
eroc144
Status: offline
quote:
Of course, the fuselage tops of all those warbirds ARE vac-formed plastic.
I never liked that detail - kinda hard to sand plastic so the joint has to be absolutely perfect. Luckily it's an easy task to cut replacement formers out of balsa, then sheet and sand it to a smooth finish!
EG
Nothing is impossible when you don''t know what you''re talking about
       Post #: 9
RE: H.O.B kits any good? - 7/1/2008 11:36:53 PM
rainedave
Status: online
The only rc kit I've ever started and didn't finish was a Lanier Stinger .10. Man, I hate vaccuform parts.
Two of my most used tools:
David
Click for fullsize
(in reply to eroc144)
       Post #: 10
RE: H.O.B kits any good? - 7/2/2008 2:12:22 AM
combatpigg
Status: offline
I just finished a HOB P-51. I also just added an inch to my biceps. If you want a good workout, these kits are great.
Led Zeppelin is NOT "old fogie" music.
       Post #: 11
RE: H.O.B kits any good? - 7/2/2008 3:34:53 AM
build light
Status: offline
My only HOB kit was the ME 109 when they had the special Norvel combo deal.
I was used to the simpler kits like the Ace series.
Boy was I surprised how full that box was and all the balsa! First thing I noticed was the plastic cowl was missing! Of course it wasen't missing once I looked the plans over.
David, nice ad for thr HOB planes.
Anyone have the ad HOB ran for the Norvel combos? Was it just the warbirds in that promo?
Robert
Keep'er light, and she will treat you right!
       Post #: 12
RE: H.O.B kits any good? - 7/2/2008 12:51:57 PM
cortacesped
Status: offline
I´m building the HOB Beechcraft Bonanza form plans. A lot of work in the wings, but they look very good. I stil don´t know what to do with the vacuum formed canopy (maybe 1/32 balsa sheeting), but let´s go step by step.
Claudio
(in reply to build light)
       Post #: 13
RE: H.O.B kits any good? - 7/2/2008 4:32:06 PM
airraptor
Status: offline
I am doing a Decathelon right now. teaching my girls on how to build them. these kits have great laser cut wood. the fus is laser marked where all formers go and bits of wood has a line to glue down to make sure everything is correct. this balsa isnt anywhere near contest grade at all. but the kit will be very strong. it has bass wood dowls for leading edge and a two piece solid spar that the ribs glue all laser maked for correct spacing. there is allot of design that went into these kits.
If you want a really light kit call them to see if they will cut you one out of some contest grade balsa. the only thing i will change on the balsa for this kit is one of the fus sides is made out of 8-10 pound balsa and the other is out of 14-16lbs stuff. I will use a OS 30 FS or a Saito 40.
the warbird plane all do very well with OS/magnum 15 in the nose and theHOB 20 size mustang will easily handle the OS32 size engines. A good engine for the 20 size stang is a webra .36 Hint Hint
(in reply to cortacesped)
       Post #: 14
RE: H.O.B kits any good? - 7/2/2008 6:34:39 PM
