build light
NE, USA Status: offline
quote:
ORIGINAL: BMatthews If you stayed faithful to the lightweight airframe and are after a slower in close and personal sort of flying then I think blowing it up to even 46 to 48 inches would be entirely acceptable. If you're after a smaller and faster model then the QTee really isn't the model for the job anyway. I'd say that anywhere from 430 to 450 sq inches of wing area and up to around 2.5 lbs would lend it that "fast powered glider" sort of performance of the smaller one. A very good observation Bruce! Anytime someone asks whether a certain engine would be good on a particular aircraft ... or if someone says they have lets say a Q-Tee or a Herr Extra or a Simple Series type plane or a Stinger before one justs answers what they have done or seen with theirs One should ask the question: What kind of performance were you looking for? A slow, in close docile plane with a light wing load type of performance or something more substantial with a minimum ability to have sustained verticle performance. Or lets say the primary concern were with wind penatration (always a plus on most folks agenda, who wants to be grounded by stiff breeze?). The Q-Tee was never intended for ailerons, outstanding verticle performance or a .15 size engine. If I am not mistaken this plane and pretty much all of the planes that call for a half A engines should need no more than that which the design was designed for. It was designed for that engine size in mind. There are exceptions of course. One certainly can gain performance by slipping in a bigger engine but is it always advisable to do so? Could be s different design may be in order. Such as the enlargement of this design so as to take a bigger engine as has been suggested. Quote: "I'm not real good at determining wing size etc, but I'd guess the more wing surface the slower it would fly. Is that correct thinking? " correct in thinking but what your are trying to achieve is a lighter wing loading. This gives "floatability". A heavy wing loading will have a noticeably higher sink rate in the glide. Robert
< Message edited by build light -- 5/27/2008 4:28:45 AM >
_____________________________
Keep'er light, and she will treat you right!
