X jet scratch build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> X jet scratch build
Page: [1] 2 3 4 5   next >   >>
Login
X jet scratch build - 5/27/2008 1:34 AM
Bob.R
Score: 100
Last Login: 4/15/2013
Status: offline
Another scratch build commenced a few months back. I'll put up a few pics as the build progresses for those interested in this kind of stuff.
It is a sport jet loosely styled after some of the mid 50's X jets. It gives me an opportunity to build a circular cross section fuse which I've wanted to do for some time.
90" oal
30# target weight (I never make my targets, but maybe this time)
1330 sq in
35# turbine
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: X jet scratch build - 5/27/2008 1:41 AM
Bob.R
Score: 100
Status: offline
The fuse was fabricated using molded balsa shells with glass and c/f both sides to form a composite structure. I did a thread with a bit of detailed discussion on the composites forum. I'll post few pics here as well.
http://www.rcuniverse.com/forum/m_7123475/tm.htm
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 2
RE: X jet scratch build - 5/27/2008 1:43 AM
Bob.R
Score: 100
Status: offline
Shells were glued up over a temporary form.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 3
RE: X jet scratch build - 5/27/2008 2:07 AM
Bob.R
Score: 100
Status: offline
The fin and turtle deck structure carries load, so it is also a composite structure, but formed differently than the fuselage shells.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 4
RE: X jet scratch build - 5/27/2008 2:18 AM
Bob.R
Score: 100
Status: offline
Bob and www.flyingfoam.com supplied the foam cores. Excellent work as usual. Had to prop the cores against the fuse and make jet noises.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 5
RE: X jet scratch build - 5/27/2008 3:24 AM
tothemax
Score: 105
Last Login: 5/17/2013
Status: offline
Very Nice!!!I would sure like to get my hands on one.
Steve
_____________________________
Steve G
Hide Signatures
(in reply to Bob.R)
       Post #: 6
RE: X jet scratch build - 5/27/2008 10:24 PM
Bob.R
Score: 100
Status: offline
Template for hot wire work; 2 lb/cu ft foam core prepped for sheeting.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tothemax)
       Post #: 7
RE: X jet scratch build - 5/27/2008 10:30 PM
SJN
Score: 105
Last Login: 5/19/2013
Status: offline
Looks fast
Sonnich Johannesen
Hide Signatures
(in reply to Bob.R)
       Post #: 8
Bob.R
Score: 100
Status: offline
1/8" balsa sheet; various c/f from acp and cst; quarter ton of bricks; wing panels out of the shucks.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 9
RE: X jet scratch build - 5/28/2008 12:15 AM
seanreit
Score: 100
Last Login: 4/26/2010
Status: offline
Bob, I have a couple questions. Is there a reason you put your balsa sheeting in the pattern that you did? I have always followed from the leading edge straight back, and you did one piece that way and the rest perpendicular to the fuse. Is there some free strength for weight gained there?
I have always cut back on the foam 3/8 both sides and installed 3/8 balsa edges for hinges. Is there an advantage to the balsa blocks you preinstalled in the foam? I assume there is cause you did it...
You put in balsa for your conrol horn, what type of horn are you going with? I have always been scared to use balsa and have been putting 1/4 5 ply for that.
Are you using carbon tissue over the gear well? My latest wings I put unidirectional carbon there and it did not work like I thought it would when I tested it I'm thinking of going with Kevlar there, for no other reason than I have tried pretty much everything else, and I have a lot of it here.
Looks awesome as always!
Hide Signatures
(in reply to Bob.R)
       Post #: 10
RE: X jet scratch build - 5/28/2008 12:18 AM
A7Bldr
Score: 100
Last Login: 5/16/2013
Status: offline
Bob, see you put all these cool photos on here, now you're getting all these questions !
I don't see anything in the foam for a wing joiner or plug in wings. Am I missing it?
Love the build!
Jim
Hide Signatures
(in reply to seanreit)
       Post #: 11
RE: X jet scratch build - 5/28/2008 12:19 AM
erbroens
Score: 105
Last Login: 5/20/2013
Status: offline
Great job as usual, congrats! this technique for rounded fuselages looks excellent.. need to try it for a unusual scale jet one day of this!
Enrique
Hide Signatures
(in reply to Bob.R)
       Post #: 12
RE: X jet scratch build - 5/28/2008 12:20 AM
GrayUK
Score: 102
Status: offline
Rob2
You are a craftsman without a doubt, full credit to you.
Paul
no one told you when to run...
Hide Signatures
(in reply to Bob.R)
       Post #: 13
RE: X jet scratch build - 5/28/2008 1:52 AM
grbaker
Score: 115
Status: offline
Bob,
That's amazing. It looks like 200++++++++++++++++++mph just sittin' there.
Gary Baker
Hide Signatures
(in reply to GrayUK)
       Post #: 14
RE: X jet scratch build - 5/28/2008 2:53 AM
Bob.R
Score: 100
Status: offline
Hey Sean, the answer to all your questions is this: artistic license. Seriously though, I like to have the sheeting grain aligned with both the leading edge and the trailing edge. The ailerons and flaps should have more torsional and bending rigidity if the grain is aligned with the trailing edge, but your method obviously works quite well. The blocks for the hinges provide a bit a more surface for the epoxy to grab (I use the large dubro flat hinges), but it may be overkill. As for the horns, I make my own out of G10 which then get glued into a deep slot in the block. I use either 3.5 or 5.7 oz c/f cloth above the wheel wells - works well. See you at the field.
Jim, it will be a one piece wing - I know, arghh. There will be c/f reinforced spar joiners and glass and c/f over the wing joint. Access to the turbine will be through the wing saddle area.
Steve, SJN, Jim, Enrique, Paul, and Gary - thanks for the kind words.
Hide Signatures
       Post #: 15
RE: X jet scratch build - 6/4/2008 2:51 AM
Bob.R
Score: 100
Status: offline
Stab similar construction to wing.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 16
RE: X jet scratch build - 6/4/2008 2:54 AM
Bob.R
Score: 100
Status: offline
Trailing edge stock fabricated with hardwood rear edge.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 17
RE: X jet scratch build - 6/4/2008 2:58 AM
Bob.R
Score: 100
Status: offline
Tested G10 control horn tear out strength in solid balsa block. Pulled 80 pounds force without failure. Equivalent to 700+ in oz torque at servo.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 18
RE: X jet scratch build - 6/4/2008 3:04 AM
Bob.R
Score: 100
Status: offline
Time to sand. Jet air filtration unit is mounted on a castered stand. Can be moved near the work and catches the majority of balsa dust.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 19
RE: X jet scratch build - 6/4/2008 3:06 AM
Bob.R
Score: 100
Status: offline
Leading and trailing edges sanded. Now ready for surgery.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 20
RE: X jet scratch build - 6/4/2008 3:09 AM
Bob.R
Score: 100
Status: offline
Elevators, flaps, and ailerons are sawn free on band saw. Blocks for hinges visible on cut surface.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Bob.R)
       Post #: 21
RE: X jet scratch build - 6/4/2008 9:18 AM
cactusflyer
Score: 110
Last Login: 4/5/2013
Status: offline
Nice work, Bob!
I have always arranged the sheeting as you did........For the same reasons. Additionally, it takes less wood to do the sheeting. Again, very nice, well thought out work.
Tailwinds,
John
Proud to be a rookie!
Hide Signatures
(in reply to Bob.R)
       Post #: 22
RE: X jet scratch build - 6/4/2008 3:21 PM
seanreit
Score: 100
Status: offline
Two things Bob, last year I started using 10 dollar Box fans with 3to 5 dollar HVAC 20x 20 filters on the back of them. Homemade "Jet air filtration" at very low cost. Set it up just as you did with yours, close to the work, picks up A LOT!
PS, yes, you can use it in your home as well!
I love love love the fish hook test on the control horn!
Hide Signatures
(in reply to cactusflyer)
       Post #: 23
RE: X jet scratch build - 6/4/2008 8:40 PM
Greg G
Score: 100
Last Login: 5/18/2013
Status: offline
Hi Bob,
Your project is looking great!!
Question for you. In post #7 what kind of hot wire bow are you using for the hole cutouts with a top and bottom template? I've been using just a wire between two handles for quick insertion into the holes.
Greg
Hide Signatures
       Post #: 24
RE: X jet scratch build - 6/4/2008 10:07 PM
kirkj
Score: 100
Status: offline
another question Bob,
your photo shows Hysol E20-HP, is that the quicker "v-poxy" style glue?
Kirk
Hide Signatures
(in reply to Greg G)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
4.313RCU1
