mtntopgeo
MT, USA Status: offline
quote:
ORIGINAL: Mr. Mugen I have a hobbico I cannot seem to get a good reading with. I get readings all over the place. Nothing is consistant. It seems like the only way I can get good readings is to put a flashlight on the other side. What do you guy's use? Been there, done that. The same manufacturer must make the Globee too. Piece of heat shrink over the photo cell, flat black paint on the prop, back to the sun, shade the unit from direct sunlight, read through the prop away from the sun, hold my tongue just right, skip around on my left foot, & hope that the planets are in correct alignment. THEN, when none of this works, bring everything into the semi-dark basement, & use the flashlight. Works every time. Anybody notice the similarities between this scenario & that of trying to get one of the sub-standard engines , (that the present manufactures are providing us with) to run as they should when we purchase them? We must be easy !!!!!!!!!!!!!!!!!!!!!! ........................... George K.
