86" Wing Retainer Pins
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> 86" Wing Retainer Pins
Page: [1]
Login
86" Wing Retainer Pins - 5/27/2008 3:21:49 PM
plasticman
Status: offline
Reza,
This past weekend I was lucky....I happened to look inside the hatch, between flights, and noticed that one of the wing retainers had vibrated out. When showing that to someone else at my club they said the newer models no longer use this method. Is that right? If so, what method is now used to retain the wings and is mine modifiable to that method? Thanks.
David.
_____________________________
Plasticman
       Post #: 1
RE: 86" Wing Retainer Pins - 5/28/2008 12:13:36 AM
wings4274
Status: offline
Thats funny i thought the 86" was the new model...
Mine has not come out yet, but when i installed it i used 80 grit sand paper to rough it up before glueing it.
Are you talking about the pin in the wing or the clip that goes in the pin?
See ya.
(in reply to plasticman)
       Post #: 2
RE: 86" Wing Retainer Pins - 5/28/2008 12:22:17 AM
plasticman
Status: offline
quote:
ORIGINAL: wings4274
See ya.
Wings,
I guess I should have been clearer. By newer model I meant more recent shipments of the 86. And yes, by the retainer pins I meant the hitch pins that slide into the anti-rotation pins.
Dave
Plasticman
(in reply to wings4274)
       Post #: 3
RE: 86" Wing Retainer Pins - 5/28/2008 3:00:56 AM
Rezagh
Status: offline
Hi Dave,
No it comes with retainer pins. I think you might have a little distance between your washer and retainer pin. Make sure it is snug, you can add another thin washer to fill up any gap. Also see if your cutter pin is going in tight, otherwise change it.
Hope this helps,
Reza
Quique's Aircraft Company
       Post #: 4
RE: 86" Wing Retainer Pins - 5/28/2008 4:31:22 PM
BaldEagel
Status: offline
This seems to work well, but the reason I did it was a lack of room after putting in a cannister exhaust into the 85"it was difficult to get my fingers down past the tank.
Mike
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
No matter what anyone says 100% is the maximum you can get.
(in reply to Rezagh)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
