Perry VP30 and Saito 100 issues
Tower Hobbies
Logged in as Guest
  Printable Version
O.S. Engines O.S. BGX-1 3500 w/ BCM #4224 Pitt
Seller:  jmhernan
Details:   $200.00   |  10/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Perry VP30 and Saito 100 issues
Page: [1]
Login
Perry VP30 and Saito 100 issues - 5/27/2008 4:12:01 PM
patrick181
Status: offline
Ive got them both running great. The issue is that the pump leaves pressure in the line and hydrolocks my engine after a run. I've tried the return line system but I just cant get the engine to run with it.
       Post #: 1
RE: Perry VP30 and Saito 100 issues - 5/27/2008 4:27:46 PM
Hobbsy
Status: offline
Patrick, is the tank higher than the carb, if so the neither Perry will stop flow from a higher tank position.
_____________________________
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to patrick181)
       Post #: 2
RE: Perry VP30 and Saito 100 issues - 5/27/2008 7:10:11 PM
patrick181
Status: offline
Yea the tank is about 1/2" higher... I should probably get an IronBay huh? I didn't think 1/2" would be that bad.
< Message edited by patrick181 -- 5/27/2008 7:12:17 PM >
(in reply to Hobbsy)
       Post #: 3
RE: Perry VP30 and Saito 100 issues - 5/27/2008 9:44:32 PM
GarySS
Status: online
Patrick...question for you. How did you mount the Perry? I tried to mount one using the bolts of the engine back cover, but could not get it leak free that way. What was your method???
       Post #: 4
RE: Perry VP30 and Saito 100 issues - 5/27/2008 10:04:56 PM
patrick181
Status: offline
quote:
ORIGINAL: GarySS
Well this is the VP30 pulse pressure unit. It's located in the firewall box of the airplane where the tank was supposed to be. Its a bit farther from the recommended location but I managed to get it running good. I could not find a place to mount it near the carb as recommended. I have not had a problem with leaks...
< Message edited by patrick181 -- 5/27/2008 10:05:48 PM >
(in reply to GarySS)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.703RCU1
