TX Battery Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> TX Battery Question
Page: [1] 2   next >   >>
Login
TX Battery Question - 5/28/2008 4:05:37 PM
Flyboy76
Status: offline
Hi, i just upgraded my TX battery in my Optic 6 from a 600mah NiCad to a 2100mah NimH. Just wondering can i still use my Wall Charger that came with the Radio for charging it?
Geoff
_____________________________
When life deals you a lemon do as i do and make a whisky sour!!!
       Post #: 1
RE: TX Battery Question - 5/28/2008 4:36:59 PM
BarracudaHockey
Status: offline
You can but you'll never reach a full charge. You want something like an Accucyle or Triton if you're going to start playing with larger batteries. A transmitter wall wart is 50 to 100mah output.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to Flyboy76)
       Post #: 2
RE: TX Battery Question - 5/28/2008 5:18:18 PM
wswanepoel
Status: offline
quote:
ORIGINAL: BarracudaHockey
I agree.
If you want someting cheaper, look at this:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=3824&Product_Name=JB_1100_Digital_Smart_Lipo/NiMH_Charger_w/_Repair&cda=36317
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=5548&Product_Name=IMAX_B6_Charger/Discharger_1-6_Cells&cda=36317
Both will get you on your way.
< Message edited by wswanepoel -- 5/28/2008 8:27:58 PM >
Regards Bill
Remember: Nose heavy planes flies like a dog. Tail-heavy planes only fly once.
(in reply to BarracudaHockey)
       Post #: 3
RE: TX Battery Question - 5/28/2008 8:11:02 PM
Rodney
Status: offline
Yes you can, it is again a simple matter of physics, if you put more energy in than leaks out (self discharge) you will eventually reach full charge. If you have an ammeter just check to see how much current you are putting into the battery with your wall wart. If you then divide the battery capacity by that value and multiply by 1.6 you will have the approximate time it will take to fully charge the battery from a fully discharged state. Edited to add the following: if that current is more than 0.1C then the 1.6 multiplier may be to high a number but it should be close.
(in reply to wswanepoel)
       Post #: 4
RE: TX Battery Question - 5/28/2008 8:29:49 PM
BarracudaHockey
Status: offline
Thats great in theory. In practice however I think you will find electrical losses and inefficency means you could put that on charge for a week and it would probably never reach full capacity.
(in reply to Rodney)
       Post #: 5
RE: TX Battery Question - 5/29/2008 2:45:41 AM
guver
Status: offline
If the rate is slower than c/10 then the multiplier goes up as well. 100 ma should charge a 2100 mah battery in about 4 days.
you hear that silence?
       Post #: 6
RE: TX Battery Question - 5/29/2008 2:51:14 AM
Flying Geezer
Status: offline
You can also dig a basement with a teaspoon!
Flying Geezer
Hughes RC
(in reply to guver)
       Post #: 7
RE: TX Battery Question - 5/29/2008 2:58:02 AM
guver
Status: offline
That would take longer than 4 days.
(in reply to Flying Geezer)
       Post #: 8
RE: TX Battery Question - 5/29/2008 6:19:52 AM
wswanepoel
Status: offline
or cut the lawn with a nailclipper
Regards Bill
       Post #: 9
RE: TX Battery Question - 5/29/2008 6:09:41 PM
Flyboy76
Status: offline
I have a Triton jr. that i can use. What setting would you reccomend for charging and discharging
Geoff
       Post #: 10
RE: TX Battery Question - 5/29/2008 6:12:38 PM
guver
Status: offline
If it's a newer version that can have the safety timer disabled then use 1/2 amp max for chargeing. Discharge is not recommended.
       Post #: 11
RE: TX Battery Question - 5/30/2008 12:09:13 AM
Flyboy76
Status: offline
so 500 mah max for charging. the safety timer can be disabled and just let it go?? does it stop when it is charged on it's own???
(in reply to guver)
       Post #: 12
RE: TX Battery Question - 5/30/2008 12:16:54 AM
guver
Status: offline
Yes, it is an automatic "peak" charger that stops when the batts are full. Disable timer or set it to 4 hrs if possible because it would take 4 hrs to do the batts if they were dead.
       Post #: 13
RE: TX Battery Question - 5/30/2008 12:30:09 AM
rlmcnii
Status: offline
500ma should cook those new 2100 AAs to well-done in short order. High-capacity AA NiMH cells do not tolerate charge rates above C/10 too well. And, unless you are in some huge hurry, there is no reason to charge them at a greater rate.
NiMH need about three cycles of form-charging: 16 to 18 hours @C/10 followed by discharge @ C/5. This method will get your cells to the rated 2100 mAh capacity.
There is a real good tutorial about NiMH batteries at the Hangtimes Hobbies website. Also, read the note about high-capacity AA cells for Tx packs. It is some good information.
< Message edited by rlmcnii -- 5/30/2008 2:36:28 AM >
       Post #: 14
RE: TX Battery Question - 5/30/2008 2:26:13 PM
Flyboy76
Status: offline
