lst 2 overheating
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> lst 2 overheating Page: [1]
Login
lst 2 overheating - 5/29/2008 11:59:59 PM
djsnider77
Status: offline
Hey guys I just got a LST2 and the engine keeps going to 300 or over any ideas ? It is also all stock if that helps
_____________________________
3 Savage x 4.6, HPI Baja 5b SS Losi LST 2 ,Losi Eight T, Traxxas Slash and the Traxxas Slayer in a few days
       Post #: 1
RE: lst 2 overheating - 5/30/2008 12:04:27 AM
LST2OWNER
Status: offline
richen the high speed needle
(in reply to djsnider77)
       Post #: 2
RE: lst 2 overheating - 5/30/2008 12:05:05 AM
full maxx
Status: offline
restart your tuning back to the factory settings ... check for air leaks (bubbles) in the fuel line esp around the filter ...make sure the fuel line does not touch the engine at any point, if all that is good you may need to seal your engine with rtv silicone but more that likely its in the tuning
check this out... www.trukz.com
       Post #: 3
RE: lst 2 overheating - 5/30/2008 12:09:14 AM
twomanytoys
Status: offline
Did you break in the engine or are you just running it out of the box? Do you have the body on or off? Overheating means you are running lean, you have air leaks or not enough airflow from the body. or all of the above.
J et A ssisted T ake O ff
(in reply to full maxx)
       Post #: 4
RE: lst 2 overheating - 5/30/2008 12:37:57 AM
Duratraxman1
Status: offline
I dont think you are having trouble tuning, because you must be good at the hobby. (you have more trucks than me) so im thinking its a tuning thing. To test the fuel line for leaks: Take the pressure line off of the exaust and the fuel line off of the carb. Pinch the line as hard as you can on the fuel side (that was on the carb) and put the line that was on the exaust in your mouth and blow. If you hear a hissing near the tank or fuel filter than you have a leak.
good luck
DURATRAX-Warhead EVO/Raze/Nitro EvaderST/EvaderST-LOSI-Aftershock/MicroT/MicroDT,AXIAL-AX10 RTR-HELIMAX-Axe CP-SUZUKI-LTZ400
(in reply to twomanytoys)
       Post #: 5
RE: lst 2 overheating - 5/30/2008 4:07:51 AM
nitronut911
Status: offline
check the fuel filter or near the primer in the tank. all it takes is somthin real small.
When your over 65, NEVER trust a fart!
(in reply to Duratraxman1)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
