Saito 1.80 RPM Games
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 1.80 RPM Games
Page: [1]
Login
Saito 1.80 RPM Games - 5/30/2008 4:29:55 AM
Ferocious Frankie
Status: offline
Hi guys,
I have Saito 1.80 approximately one year old on a slimline pitts muffler. I've had some problems where I've been flying my plane for say 7 minutes at half throttle and when I've come in for final my engine has quit. This happens when I bring the engine to idle. It has also quit when I've gone to idle coming out of a hammerhead or loop. The engine runs great on the ground with the high speed 300 rpm off the max. Also, when I tilt the nose of the plane 90 degrees up, I get a little RPM gain and when I tilt it down, I get a little RPM loss. I have checked all the lines in the tank and everything is fine. No air leaks or anything. I'm contemplating if the heavy APC 18x6W prop that I have on the engine puts too much of a load on the engine and this causes this problem. At idle, I get a little smoke and at full throttle I also get a little smoke. When I immediately go to full throttle I get a little more smoke and it clears up and goes back to a little smoke. Idle is around 2500-2700 RPM. Using Omega 15%.
Any suggestions???
< Message edited by Ferocious Frankie -- 5/30/2008 4:31:46 AM >
_____________________________
"To fly is everything." -Wright Brothers
Club Site: www.sccmas.org
       Post #: 1
RE: Saito 1.80 RPM Games - 5/30/2008 12:54:02 PM
Hobbsy
Status: offline
Frankie, if 2,500 is as slow as it will idle the LS needle is too rich, lean it until it will idle @ 2,000 rpm. You don't have to fly it at a 2,000 rpm idle you just need to set it so it can.
"I have gone faster backwards, upside down and on fire than most people have gone at all" Don Garlits
(in reply to Ferocious Frankie)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
