AirBorne Models "TameCat" Trainer Assembly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> AirBorne Models "TameCat" Trainer Assembly
Page: [1] 2   next >   >>
Login
AirBorne Models "TameCat" Trainer Assembly - 5/31/2008 4:31:07 AM
Bill Diedrich
Status: offline
One night I was looking for a new "Sporty Type" plane and while looking through various sites I came across
the Jeff Troy "TameCAT" trainer on the AirBorne Models site and decided it was one of those "gotta have it cause
it's different" kind of airplanes. and the price tag of $109.99 plus shipping made it even more appealing. So out
came the plastic and the order was placed over the air waves. The box arrived in about 7 days, shipped FedEx ground.
Upon opening the box I first inspected all of the parts and found that the forward tank cover/canopy was severely
cracked, a phone call that evening to Steve @ AirBorne Models had a replacement on the way the next day.
Oooppps, it arrived in about 5 days and was crushed beyound recognition by UPS, driver didn't seem to care either.
Another phone call that evening to Steve again had another one on the way next day via FedEx and a claim filed with UPS.
One thing for sure the guys at AirBorne are really tops in "CUSTOMER SERVICE"......... Anyway I started the assembly
this evening and here are some pics to wet your appetite.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Bill Diedrich -- 6/5/2008 4:24:05 AM >
_____________________________
Waco Brotherhood #43
       Post #: 1
RE: AirBorne Models "TameCat" Trainer - 5/31/2008 4:37:59 AM
Bill Diedrich
Status: offline
After about 1 1/2 hours of work I had all of the control surface hinges super glued
and the wings joined with 30 minute epoxy. The stab & elevator, fin & rudders assembled
all with 30 min epoxy, and setting for the night to cure.
Plan is to have this baby ready to go for it's maiden this Sunday afternoon.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Bill Diedrich)
       Post #: 2
RE: AirBorne Models "TameCat" Trainer - 6/1/2008 4:49:06 AM
Bill Diedrich
Status: offline
Well it's been a long day but got a lot done one the TameCAT. Ist pic shows the wing sitting in place after
letting epoxy dry overnight. 2nd pic shows aileron servos installed, 4th pic shows tight comaprtment of the
nose gear steering arm ( big hands don't fit too well in there). 3rd pic shows her on all 3. Had a time
getting the nose gear installed as it is a tight space to manuver an allen key to tighten it all up.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 3
RE: AirBorne Models "TameCat" Trainer - 6/1/2008 5:02:14 AM
Bill Diedrich
Status: offline
The tank assembly was a longer than normal process due to the center screw that tightens
the stopper kept stripping, after serveral tries I changed it out for another M-3 screw that
finally tightenend up. Pic 1 shows the tank mounting method of a rubber band hold-down,
Pic 2 shows the neat bomb that is suspended from the belly, it is held in place by a spring
loaded clip, so that it can be removed if wanted. Was really trying to get her ready for
her maiden tomarrow but time was running out, had to get my other planes ready for the
field.
Click for fullsize
Click for fullsize
       Post #: 4
RE: AirBorne Models "TameCat" Trainer - 6/1/2008 5:34:57 AM
Kmot
Status: offline
I saw this plane at the recent AMA Convention and thought too that it was a unique and very good looking model. The price seems quite reasonable. UPS is costing Airborne any profit they may have realized in the beginning. I am reading more and more about model airplanes arriving with all sorts of damage. The Mfg's need to realize that the UPS goons make a sport of destroying packages and they need to pack for "America" as opposed to a civilized country.
DRILL BABY DRILL!!!
       Post #: 5
RE: AirBorne Models "TameCat" Trainer - 6/1/2008 11:02:51 AM
Gary L.
Status: offline
Cool..
We''re all here because we''re not all there !! AMA # 884678 Proud to be a volunteer firefighter !
(in reply to Kmot)
       Post #: 6
RE: AirBorne Models "TameCat" Trainer - 6/1/2008 1:25:40 PM
Bill Diedrich
Status: offline
What is really neat about this plane is the packaging of all of the accessory packs a number keyed to
the parts layout sheet. Each little bag has it own number on it which coresponds to what it is used for
in the assembly sequence. Upon inspection of the glue joints and fuselage former to sides and
re-enforcements, evrything looks very good but as a precaution I will add a little CA to all of the accessable
joints. I would also recommend that the fuel tank compartment be fuel proofed with clear dope.
All in all I am very impressed so far with this model and look forward to getting it in the air next weekend.
On the UPS comment, AirBorne ships all of their kit orders out via FedEx Ground, just accessories and replacement
parts are shipped UPS. I have had a fare share of Tower Hobbies orders arrive with the box in less than
acceptable condition.
< Message edited by Bill Diedrich -- 6/5/2008 4:24:52 AM >
(in reply to Gary L.)
       Post #: 7
RE: AirBorne Models "TameCat" Trainer - 6/5/2008 4:19:49 AM
Bill Diedrich
Status: offline
Got the engine mounted this evening. My GMS 47 was putting the supplied engine
mount in a bind as it wasn't wide enough so off to the LHS to get a Great Planes mount,
I chose the 40-70 mount as it was the closest to the hole spacing. I punched out the
factory installed T-nuts and turned a piece of 5/16" birch dowel down to 7/32" which
fit the hole snug and applied thin super glue. Applied the patern to the firewall, drilled
new holes, 3/16" dia. for the 6-32 T-nuts. Made a handy jig to space the engine the
required 4 1/4" from the firewall. Used my centering drill tool, marked the holes, drilled
and then mounted engine.......continued tomarrow evening.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 8
RE: AirBorne Models "TameCat" Trainer Assembly - 6/5/2008 5:00:31 AM
Kmot
Status: offline
Lookin' good!
DRILL BABY DRILL!!!
       Post #: 9
RE: AirBorne Models "TameCat" Trainer Assembly - 6/7/2008 6:50:23 AM
Bill Diedrich
Status: offline
After a long evening the TameCat is ready to fly Saturday weather permitting.
Will post some finished pics later in the morning
A couple of thoughts about the assembly, I should have put the rudder horns on
before I glued them to the top of the Stab, as they were a bear to fiddle around with
trying to get them right. The screws that fasten the nose cone of the spinner to the
back-plate should be replaced, the phillips heads on mine stripped very easily, replaced
with a compareable sized S/S sheet metal screw with an allen head for ease of thightening
Will weigh before heading to field and will hopefully be able to post some video of the maiden.
(in reply to Kmot)
       Post #: 10
RE: AirBorne Models "TameCat" Trainer Assembly - 6/7/2008 4:26:49 PM
nemesis4u
Status: offline
Just purchased one for my wife as a TRAINER II.
She had another trainer and didn't like the way it looked...
So....................
KEEP UP THE POSTING! I know this will be a great flyer!!
-nemesis4u
Oh btw... yes her canopy was also cracked... waiting on a replacement too! I bought it at a LHS 2nd Chance R/C in Universal City, TX.
When I got home from Universal City/San Antonio TX I unpacked the TAMECAT and found the cracked canopy,..
R/C WARBIRDS / RC TANKS ENTHUSIAST
VQ WARBIRDS, KMP, & RCV
       Post #: 11
RE: AirBorne Models "TameCat" Trainer Assembly - 6/7/2008 5:42:06 PM
Bill Diedrich
Status: offline
nemesis4u, I thought that you guys would be at Bomber Field this weekend>>>>>>>>>>
I finished things up late last night, balanced it this morning, it took 2 1/2 oz. of lead in the tail.
could have gone with 3 but want to check out the first flight, I like mine a little on the nose down
attitude. Weighed the plane dry 6 lbs, 4 oz. with the 2 1/2 of lead in the tail.
Here are some pics of the finished plane.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Bill Diedrich -- 6/7/2008 5:48:33 PM >
(in reply to nemesis4u)
