Spacing for rib stiching 1/3 cub
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> Spacing for rib stiching 1/3 cub
Page: [1]
Login
Spacing for rib stiching 1/3 cub - 6/1/2008 5:52:26 PM
henson
Status: offline
I need some help in finding the distance between the stiches on a 1/3 cub
       Post #: 1
RE: Spacing for rib stiching 1/3 cub - 6/1/2008 7:21:33 PM
khodges
Status: offline
I think that every two inches is pretty much standard on fabric wings, regardless of type. I know the WACO's I saw in St. Louis were all two inches on their stitching on the wings. It may vary on the fuse, a bit further apart, because the airstream is not trying to pull the material off the frame (ballooning) because of lifting loads.
I just did a search, because this interests me a lot. I can't find the specific distance for the Cub, but stitch spacing varies with the Vne speed of the respective airplane type. I don't know if this link will come up, but try this, and download the pdf reference it mentions. There are a bunch of diagrams showing how to tie the knots and make the stitches on a full-scale, and it talks about re-covering and not to exceed the original stitch spacing, etc.
www.auf.asn.au/scratchbuilder/fabrics.html
< Message edited by khodges -- 6/1/2008 7:57:05 PM >
_____________________________
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
(in reply to henson)
       Post #: 2
RE: Spacing for rib stiching 1/3 cub - 6/1/2008 10:14:23 PM
henson
Status: offline
Thanks khodges,
Right now Iam ready to simulate the stiching on the tail feathers.Two inches seem to be pretty far apart for them I may just make my own spacing up.I wont be entering it into any scale contest.Its just for sport flying.
(in reply to khodges)
       Post #: 3
RE: Spacing for rib stiching 1/3 cub - 6/2/2008 12:26:35 AM
SoCalSal
Status: offline
quote:
ORIGINAL: henson
Thanks khodges,
You can go 5/8 inch between stitches for 1/3 scale.
Let''s be open minded.... But not so open that your brain falls out
       Post #: 4
RE: Spacing for rib stiching 1/3 cub - 6/2/2008 4:26:01 AM
henson
Status: offline
Iam will start on it tomorrow night.I went with the stits covering,and will do the glue with the t-pin trick like they showed in the video.
(in reply to SoCalSal)
       Post #: 5
RE: Spacing for rib stiching 1/3 cub - 6/2/2008 10:24:26 PM
Rocketeer10
Status: offline
I built a Balsa USA 1/3-scale Cub into an L-4 many years ago, 1991 or so, and I measured a full-size L-4 wing. The actual spacing was 3 inches apart so I made the model stitches, 1 inch apart. Also an interesting note is that the stitching on the tail surfaces and fixed fin, are not taped leading edge to trailing edge. Rather, they are covered by small 3 inch diameter circular patches with pinked edges making them look like little "sun" faces. Also not every three inches. I believe there were 3 on each rudder and elevator/stab rib equally spaced and only one or 2 on each side of the fin.
For what it's worth.
GY
"I like it!!!"
       Post #: 6
RE: Spacing for rib stiching 1/3 cub - 6/3/2008 2:49:01 AM
henson
Status: offline
Thanks for the info,
Looks like I wont be able to start it till tomorrow.
(in reply to Rocketeer10)
       Post #: 7
RE: Spacing for rib stiching 1/3 cub - 6/3/2008 11:30:37 AM
BOB MOORE
Status: offline
I am an A&P an I have covered 35 Planes and were seven Cubs,The stiching is every three inches except in the prop blast,then it is two inches.
       Post #: 8
RE: Spacing for rib stiching 1/3 cub - 6/3/2008 11:36:46 AM
BOB MOORE
Status: offline
I was having trouble with my computer,It depends on HP of engine and if it will be used for Aerobratic. On planes like a Staggerwind the stiching is every 1". On stearmans it is 2" and 1'" in prop blast. BOB MOORE
(in reply to BOB MOORE)
       Post #: 9
RE: Spacing for rib stiching 1/3 cub - 6/5/2008 8:41:17 PM
henson
Status: offline
Thanks for the help.I decided to go with a 1inch space on the tail feathers.The glue on the t-pin trick works really well.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.546RCU1
